07-25-2017, 03:49 AM | #1 |
Drives: 2017 ZL1 and 2016 GMC Sierra Denali Join Date: Jul 2010
A10 Launch Control...
Hey guys...
Newb here....does the 2017 A10 Camaro ZL1 have launch control? If so, how does one use/engage it? Look forward to you people's feedback. Thanks very much |
07-25-2017, 04:14 AM | #2 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
07-25-2017, 06:46 AM | #3 |
Drives: '21 ZLE A10 Join Date: May 2012
yes...both the A10 cars and M6 cars have launch control. I haven't tried it in my A10 car as I am still in the break in period. With the A10 the rpms are limited to 2400 with launch control.
07-25-2017, 08:37 AM | #4 | |
Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
There are nominal settings until they are changed....
08-06-2017, 02:18 PM | #5 | |
Thanks very much. I got to the customization screen wherein you adjust the launch rpm and slippage. First time ZL1 owner so please bear with me. What is slippage and why would you adjust that? I mean wouldn't you always want 0% slippage ? Lastly, I think I'm doing something wrong because after setting launch rpm to 2400rpm which was the limit, I applied left foot brake and right foot on the gas but like a normal burn out, my wheels start spinning. Any idea what I am doing wrong? |
08-06-2017, 02:33 PM | #6 | |
slippage about 5-8% I would start at..... launch at about 1800-2000 rpm.......
08-06-2017, 11:51 PM | #7 |
Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
same here, i set rpm hold brake hard hot gas but i start a burn out, i just gave up as i heard launching myself is quicker anyway
08-07-2017, 12:05 AM | #8 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Launch control can be a bit tricky sometimes. You have to really stand on the brake hard and slam the gas to the floor really fast. Do either one of those wrong and the car will try to spin the tires.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
08-09-2017, 05:24 AM | #9 |
I messed around yesterday with it.... you have to have TC and Stabilitrack disabled for it to work..... when I just disabled TC it torched the tires....
So push the TC button on the console down twice to turn both off.... first push is TC and the second is Stabilitrack...... if you just hold it down for 6-8 seconds it shuts it all off.... but make sure you know your car because no nannies are on this way.....the car can get away from you if you are not careful....
08-09-2017, 07:59 AM | #10 |
Yes. You have to enter PTM by pushing the button twice before you can get into line lock and launch control.
I don't think you can get into launch control if you just hold it down and turn everything off can you? I don't remember trying that to see.
08-09-2017, 08:33 AM | #11 |
Yes, I use sport mode more than track mode. Better 60 ft. times with sport than track right now. Like you have done I have tried many scenarios to launch, and the best to date is no launch control, brake hold at 1800-2000 rpm and a tip in off the line....like you described in your recent time slip thread. TM is not as much a hinderance that way..... so far.... I have a couple more scenarios to try.... once I get a better handle on it, I will let you know the results....
08-09-2017, 08:57 AM | #12 | |
I'm also using sport mode for my general setting with everything off at the strip. I've only played with launch control a little on the street and thus far it's slowed me down, but I believe one could dial it in to work with enough time. I really think launch control will shine once the car is modded, making big power, with TM disabled.....if it can be used with low air pressure like someone said the other day.
08-09-2017, 09:02 AM | #13 | |
08-09-2017, 09:25 AM | #14 | |
I just remembered another thing I left out of my street car takeover thread about my first run that could've been why I spun so much on the launch. I tried 26 psi in the rear to see what happened, planning to play with launch control some for the first time at the track, but quickly dropped the air back down to 18 after looking at my tires after that run and seeing I had about 1/2 inch of tread on the outer edge that hadn't touched the track. I've been running around with traction compound from the track on the outer edge of my rear tires from the first track event back in May because that part of the tire doesn't touch the ground at full air pressure or even at 26 psi apparently. My tire pressure ended up dropping to 17 after sitting 3 1/2 hours and the outside temp dropping as it turned night. That's what I left the pressures at for my fastest pass. I should've checked the air before I made the very last run, because I'm sure it went back up some from the previous pass.
Tags |
launch control |
