Old 11-15-2021, 07:10 PM   #1
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Front control arm replacement?
My 2010 Camaro SS has 161xxx miles and I’ve gotten a huge clunk in front end when hitting any bump, crack, or buckle in the road. I could feel it vibrate all through the car last time out. I’ve been reading and I think the front control arms, bushings and joints are perhaps shot.
My car is lower on Ridetech coilovers 1.0” +/- already and that’s the only front suspension mods so far.
Am I in the right track?
Anything else I could replace easily at this time?
Would Z/28 control arms be direct replacement and upgrade?
ZWA SS is offline   Reply With Quote
Old 11-15-2021, 10:18 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yeah mine went bad around 150k but there are two sets of lower control arms on each side of the front. There's the front lower and the front lower rearward arms. I had a bad clunk in the front too so replaced both set. The bushings were bad in them. That seemed to solve the problem.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 11-16-2021, 04:39 AM   #3
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
These are what I’m looking at.
Old 11-16-2021, 05:22 AM   #4
morepowerjoe
Yep those are it.
Old 11-16-2021, 09:53 AM   #5
snags18
Drives: 2010 Camaro 2SS
I know control arm part #23105018 and 9 have harder bushings. Is there any benefit to upgrade to the "lower rearward" z/28 control arms?
snags18 is offline   Reply With Quote
Old 11-16-2021, 05:39 PM   #6
KillboyPowerhead
Drives: 2015 Z/22
23105018/9 are the radius rods and have the same bushings as other trim levels but come with stiffer nylon inserts compared to the softer rubber inserts on other trim levels, improving steering response and reducing dynamic toe changes especially when braking.
The "lower rearward" Z28 arms have a stiffer bushing compared to other trims, further reducing dynamic toe changes under hard acceleration/braking. The non-Z28 bushing is known to be very well made so unless you track the car you probably won't notice much difference.
KillboyPowerhead is offline   Reply With Quote
Old 11-16-2021, 06:35 PM   #7
snags18
Killboy.......Appreciate the response!
John
