04-27-2015, 08:31 AM | #1 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
HOW TO CLEAN ZL1 SUEDE STEERING WHEEL?
Good morning, I just traded up from my 2013 2SS to a 2014 ZL1. It has a suede steering wheel. I hate a steering wheel when it gets sticky. With the black leather steering wheel, I would spray windex on a paper towl and wipe the wheel a couple of times. I did this once a week.
Can I do the same with the black suede ZL1 steering wheel? Thanks again for all your help Dimitri |
04-27-2015, 08:50 AM | #2 |
Cone Killer
Drives: 2012 SS Join Date: Dec 2013
If you go to a shoe store/somewhere that sells shoes, they should carry suede cleaning blocks and brushes. The block can be a little messy, but it'll make it look good as new
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out! |
04-27-2015, 09:04 AM | #3 | |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
Use the cleaning blocks and will look good as new. I would not use windex on suede.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
04-27-2015, 09:08 AM | #4 | |
Dimitri
I am not interested in what it looks like. That would be great if it was not my daily driver. I put 100 miles on it every day. Any other suggestions? |
04-27-2015, 09:34 AM | #5 |
The enjoyment never ends
Drives: 2010 1LT/RS IOM #25223 Join Date: May 2009
Idk if I would use windex, but I would suggest getting meguiars quick interior detailer at a store. Spray it onto a towel and wipe the steering wheel down with that. I would think that the alcohol or ammonia in windex could cause some issues.
04-27-2015, 10:06 AM | #6 |
Cone Killer
Other than wearing gloves, that's probably your best bet. Suede gets nasty when it gets saturated with dirt and oil, and the fibers get matted down. A suede block and brush will pull that crap out, and raise the fibers back up. In order to keep the wheel feeling good, you have to regularly maintain it.
04-27-2015, 10:59 AM | #7 |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
Definitely don't use windex... That's going to adversely affect the quality and deteriorate it faster.
Detailing is an involuntary obsession.
04-27-2015, 11:04 AM | #8 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
DONT USE WINDEX IT WILL RUIN SUEDE. Buy a suede cleaning kit it usually involves a rubber eraser and a brush(tooth brush will work too) you work the area with a rubber eraser then raise the fibers with the brush. makes the wheel look brand new. Mine still looks like new from the factory!
04-27-2015, 11:06 AM | #9 |
I bought this http://m.cvs.com/mt/www.cvs.com/shop...t-skuid-102984
04-27-2015, 12:22 PM | #10 |
Dimitri
In the morning when I get my coffee at Starbucks, the door knob is sticky. At the gas station the pump handles are sticky. The hand rail I hold onto at work going up and down the stairs is sticky. I need to be able to wash my steering wheel with something. The brush does not wash the wheel. I will never be driving on a road coarse to take advantage of the grip advantage suede has to offer.
Any other ideas? |
04-27-2015, 02:40 PM | #11 |
Drives: 03 BLK SSS, 13 BRM ZL1. Join Date: Feb 2012
I keep a small bottle of hand sanitizer in center console, which I use after getting gas or any time I feel the need to use. My understanding is the material is alcantara. There is a cleaner for it by Sonax. I have a bottle which I haven't used yet. I found that most of the dirt is from my hands being sweaty. So I picked up a dash crevice detail brush set at pepboys. There is a brush in the set that I used and helped clean the steering wheel. Using the brush leaves a mess so used a small vac I have to help with cleaning. Came back to as good as new. Thus, no cleaner was used just the brush and vacuum. evetually I expect to use the cleaner. Hope the pic helps.
04-28-2015, 12:23 PM | #12 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
I agree. Keep something in your car to keep your HANDS clean.
The only ways of cleaning the suede have already been provided. I don't know what else you expect to hear. Otherwise, get one of those cheesey wheel covers or replace the wheel. |
06-15-2015, 07:13 AM | #13 |
Drives: 2015 ZL1 Bright Yellow Join Date: Apr 2015
I always keep a mini-size hand sanitizer in the car and I do not touch anything before I clean my hands with it.
06-15-2015, 11:08 AM | #14 |
Lurking in my SS
Drives: '14 2SS/RS L99 Join Date: Jul 2014
