06-12-2015, 09:52 PM | #1 |
Drives: 2013 SS Join Date: Apr 2015
Microfiber Madness Dry Me Crazy Towel
Just curious if anyone else is having this same issue.
So a few months back I was reading reviews on the best dry towel, as I was using a crap ton of clothes to dry my entire car. I ended up getting the "Microfiber Madness Dry Me Crazy" & it was probably the best thing that ever happened to me. So after a few months I was like damn I should get a second... Well now on the third wash with the second one & it sheds more then my damn husky in the summer. Every swipe I am getting tons of little white tiny strings.... I do not remember this even happening once with the first one. Yes, I washed it before use... and washed it properly each time after use. I thought it would go away by now or atleast let up a bit. Did I just get a bad one? Anyone have a good way to get rid of these? |
06-12-2015, 09:58 PM | #2 |
Drives: '13 2LT RS,Blue Ray Metallic/mojave Join Date: Mar 2013
Sounds like a bad one to me. I have three of these towels, bought at separate times, and they simply do not shed at all. And I have a dark car, so I'd see shedding if it was happening. Maybe you should try contacting the with the story?
06-12-2015, 11:52 PM | #3 |
I thought I would see if anyone else had the same issue before I complained to them. Good to know most are like the first one I had.
Thanks for the reply! |
06-13-2015, 11:49 AM | #4 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
I've been using one for 4 or 5 months, and I wash it after every use; no shedding at all, and it's still holding together fine.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
06-13-2015, 02:46 PM | #5 |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
I have two of them bought at different times and have had zero issue with shedding. Must be a bad batch that one came out of. I live in Gilbert by the way
Detailing is an involuntary obsession.
06-13-2015, 03:28 PM | #6 |
Yeah, I was very surprised with the second one I had... so much lint all over. I used the leaf blower and most of it blew off. I am not going to complain & just order another.... I probably would not of noticed it as much if my car was not black.
Jtruck, I just moved down here not to long ago from Colorado... how the hell do you deal with this heat! I need to AC my garage or somethin. Your car is clean, you use the fire/ice combo? |
06-13-2015, 05:13 PM | #7 |
I have two and have never had this issue. If you purchased this from Sky's The Limit Car Care, I'm 100% sure Corey would make it right. The only other vendor I know of is Shine Supply in CA, if you bought from them, I would contact them with this issue.
You can e-mail Microfiber Madness directly from their website, they are also on Facebook. |
