07-14-2015, 12:40 PM | #1 |
Drives: 1995 m6 F1a Join Date: Jul 2014
when do u need sub frame connectors??
Hey guys, pretty new to 5th gens. car is an auto with 1200 whp. has all the goodies in suspension other than sub frame connectors. Car has no cage as of now. will be building one come winter. Do i need connectors?? very little drag strip running. mainly street.
07-14-2015, 01:18 PM | #2 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
With 1200hp I think I would probably want solid subframe bushings. Thinking of all the things that would need to be done to handle 1200hp I'm kinda suprised you would even have to ask about it...
Hell, I want some solid bushings and I only have 450 or so hp.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
07-14-2015, 01:28 PM | #3 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
I think he means connectors not bushings
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
07-14-2015, 01:43 PM | #4 |
Awe your right I missed that. I had to search, I hadn't really seen subframe connectors for the 5th gens. Now I have. Inserting foot in mouth.
07-14-2015, 01:53 PM | #5 |
correct. sub frame connectors. car has solid bushings already.
07-15-2015, 07:41 AM | #6 |
no one else...?
07-15-2015, 08:43 AM | #7 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
You need to see if you have wheel hop first. If it has full bushings and the correct alignment and still hops, then do it. The connectors add weight, so I would consider them a last effort.
07-15-2015, 11:12 AM | #8 |
'It's an experiment'
I'm going with the Hotchkis Max Chassis -- I have the BMR poly's right now, but solids in the future -- this should help me...
-Don
747 RWHP 794 RWTQ
07-16-2015, 06:56 PM | #9 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
I think since your adding a cage in the future and have no road course plans you don't need sub frame connectors. I think in your case it would just add weight. The 5th gen is already tied together pretty well from the factory unlike previous gens.
07-16-2015, 08:02 PM | #10 |
Ed
Drives: 2013 AGM Camaro 2SS/RS/1LE Join Date: Dec 2012
this.
07-16-2015, 08:51 PM | #11 |
I'm curious about the subframe connector cause I upgraded my rear suspension by installing trailing arms, toe links, upper control arm bushings, and solid subframe mounts yet I still get wheel hop. Rwhp is 692 and rwtrq is 585. I had problems doing a burnout at the track if I didn't spin the tires in the water box coating my DR with water.
07-16-2015, 11:57 PM | #12 | |
Boosted Moderator
I just moved to a ten point cage welded in and yes that will stiffen it a bunch... If you are going to be adding a welded in cage, then I would save the money for other mods... Just my opinion...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
07-17-2015, 04:58 AM | #13 |
thanks guys! ill be holding off with the connectors and just do the cage.
07-17-2015, 07:50 AM | #14 | |
