Old 01-07-2022, 11:09 AM   #1
kiteman
Drives: 2012 45th Camaro, 2SS/M6
very low MPG
2012 camaro 2ss m6
getting about 10mpg combined, it has 65,000 and admittedly the last 2 years have been crazy lost a job, wife, moved across the country bought a home, etc i have neglected my poor car lol. so i haven't done any real maintenance at all other than oil changes. i am thinking fuel filter replacement and spark plugs might be a good place to start? my k&n could probably use a cleaning as well. let me know if you guys have any suggestions; i don't want to go overboard on things that probably won't help much. thanks!
kiteman is offline   Reply With Quote
Old 01-07-2022, 12:24 PM   #2
SaReNi
Drives: 2012 SS
my 12 isn't great either that I just purchased. going to be doing what I can to boost it up abit.
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 01-07-2022, 12:39 PM   #3
xstuntman
Drives: 2012 Victory Red LFX
Hows it running?
Hard starts, surging, any smoke?
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
Old 01-07-2022, 01:28 PM   #4
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
You don't have a serviceable fuel filter in your car, it's built into the tank.
I would check the plugs, but you also need to get a data scanner hooked up to the car to see what is going on
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 01-07-2022, 01:43 PM   #5
myold88
myold88's Avatar
My early '10 SS has 67,000 miles and after 12 years I have done 17 oil changes and that's about it other than tires, batteries, etc.
It gets about 16 MPG locally and 23-24 on the highway just as it always has. It's never been abused in any way.
I believe in "If It's Not Broke, Don't Fix It."
Old 01-07-2022, 02:22 PM   #6
kiteman
are you talking about a typical obd2 scanner like you can get at autozone, or something else (i thought those only reported check engine lights, etc).
btw the car runs fine, i don't notice any issues with it and doesn't smell like it's running rich or anything like that.
Old 01-07-2022, 03:37 PM   #7
ChibiBlackSheep
Something else. Something that monitors your sensors and sees what the car is commanding. 10 mpg is very low, could have a stuck open injector, could have the car commanding way too much fuel, etc. You need a data logger hooked up and looking at what the computer is trying to do.
Old 01-07-2022, 04:34 PM   #8
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
Get rid of that filter!
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 01-11-2022, 02:31 PM   #9
kiteman
what filter do you recommend? do they make a paper cone filter? the one that came with the cold air intake kit had the K&N filter.
Old 01-11-2022, 03:07 PM   #10
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Get your data scanner and monitor your MAF warm at idle with the a/c off. Should see right around 7.5gps. then look at your fuel trim, if it's less than 10% +/- it's operating as designed. Try calculating the old fashioned way, fill the tank and keep track of the miles driven then refill and do the math. Also, alcohol content in your fuel can effect fuel economy as well but 10mpg doesnt seem possible regardless.
NOT A 45 is offline   Reply With Quote
Old 01-11-2022, 04:04 PM   #11
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Put the factory intake and filter back in (unless you have a tune for that CAI).
Rock-It Man is offline   Reply With Quote
Old 01-12-2022, 09:28 AM   #12
kiteman
can someone link me to a scanner that would work? would a regular mechanic/dealer be able to do this for me (and not charge me something insane)?
it's been on for a decade with no issue on mileage until recently, not to mention when i moved across the country i tossed the stock one anyway.
Old 01-12-2022, 11:52 AM   #13
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
I have a CAI and a little tune, avg 20.8mpg on my 100 or so mile per day commute.
I was getting dead nuts 21 but we “fiddled” with the software a little more and I lost a little.
ADVMax is offline   Reply With Quote
Old 01-12-2022, 01:11 PM   #14
NOT A 45
NOT A 45's Avatar
FYI, if your going by what the car is telling you, a skewed fuel level sensor will effect the algorithm in the ecm and falsely report mpg. If the MAF and fuel trim parameters are within spec, you don't have a fuel consumption problem on a basically stock engine.
