02-14-2022, 12:50 PM | #1 |
Drives: 2014 Camaro 2SS Manual Join Date: Feb 2018
Steering wheel swap (auto wheel on manual trans) to use paddle shifters as buttons..
I would like to know if it is possible to put an automatic steering wheel on a manual trans car with the following as the ideal end state:
1. Airbags work. 2. Factory cruse, radio, etc work 3. Left paddle shifter used for something like momentary line lock button. 4. Right paddle shifter used for something like nitrous or scramble boost button. I have looked around a bit and have not seen anyone try it. The closest I have seen is putting the line lock button on the cruse control cancel button with a bit of a homebrew circuit. Any suggestions, previous attempts, posts I could not find, jokes or comments would be helpful. Thanks! Last edited by Shtiggs; 02-14-2022 at 07:22 PM. |
02-14-2022, 02:20 PM | #2 | |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
02-14-2022, 02:39 PM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Is the resistor built into the switch? if not they should be able to handle the voltage/amperage to trigger a relay.
02-14-2022, 07:34 PM | #4 | |
https://www.camaro5.com/forums/showthread.php?t=340493 I am not sure what the automatic steering wheel harness looks like or if the shifter paddles sit on a separate slip ring that I can just order and do some testing on, I don't think it is. I have not removed my steering wheel and don't know if the connectors are the same and if there are existing unused wires that extend in the harness of the manual that we could repurpose for this use case. Would anyone be interested in something like this? I don't think it is impossible and would be really useful in the end but I am silly and like to keep stuff as close to stock on the interior as I can. |
02-15-2022, 06:48 AM | #5 |
Yes, the left switch has 2 resisters...a 4120 ohm and a 1370 ohm. The right switch has a single 634 ohm resister built in. Another issue you will have even if you can figure out how to bypass the resistor in the switches is that both switches are spliced together before going through the coil assembly so both switches would control the same device.
02-15-2022, 10:41 PM | #6 | |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
02-16-2022, 08:43 AM | #7 |
Just thinking out of the box , maybe try a different approach... just install after market paddle shifters onto your manual wheel (if they can be attached ) and wire them directly to what you want.
02-16-2022, 08:56 AM | #8 |
02-16-2022, 10:57 AM | #9 |
Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
Spell check "Resistor"
I have the full schematics of the steering wheels if you need them. I installed a 2016 heated steering wheel in my 2011. It was a painful process but now I have another vehicle for the winter and i don't even use it |
02-16-2022, 02:19 PM | #10 |
Yinz is right...lol Wasn't paying attention.... I'd love to hear details about the heated steering wheel and how you made it work.
02-16-2022, 05:44 PM | #11 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
I would keep your steering wheel and get after market paddles on it and wire it yourself.
02-18-2022, 07:38 PM | #12 |
I am really into keeping things look close to stock. most people would not notice small details like a wheel swap. I really appriciate the information.
02-22-2022, 02:06 PM | #13 | |
https://www.camaro5.com/forums/showt...=337879&page=2 |
02-22-2022, 03:55 PM | #14 | |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
