Old 10-11-2013, 11:20 AM   #1
aggieguy13
aggieguy13's Avatar
Drives: 2013 SS/RS VR 1LE
Npp replacement diffuser fitting?
So I'm looking into a Titanium cat-back. I currently have NPP just not quite loud enough. But my question is, is the dual exit exhaust going to be interfered with my diffuser since the one that comes with the NPP system is a little different?
2013 SS/RS 1LE VR-Backup System, SOLO Perforsance HF Cats, Muffler Delete, BBK Off-road X-pipe
2002 35th Aniversary SLP SS-Sold
aggieguy13 is offline   Reply With Quote
Old 10-11-2013, 11:35 AM   #2
DHSS
DHSS's Avatar
Drives: Empty
Are you looking to buy a single tip exhaust system on each side instead of the quad tip npp?
DHSS is offline   Reply With Quote
Old 10-11-2013, 11:36 AM   #3
DHSS
DHSS's Avatar
Drives: Empty
Like a Borla, Magnaflow, corsa etc......................????
Old 10-11-2013, 11:41 AM   #4
aggieguy13
aggieguy13's Avatar
It's going to be a dual exit. (1 each side)
Old 10-11-2013, 12:16 PM   #5
DHSS
DHSS's Avatar
Drives: Empty
Just add the regular Dual diffuser ($70) on gmpartsdirect.com, pull the fuse and install an aftermarket catback like the 2010-2012 models.
1 - 1 of 1 Parts 1 BODY HARDWARE / REAR BUMPER / BUMPER & COMPONENTS / Lower cover Lower cover W/O ZL1, SS
MSRPOnline Price$112.46 $70.18View Part Diagram -- Item #19
Old 10-11-2013, 01:29 PM   #6
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
FYI ... The sound and power restriction is in the OEM cats. I would suggest replacing those with a set of high flows, and the stock NPP will come alive. Even just replacing the stock NPP with an after market cat back will be disappointing with the OEM cats in place.
Old 10-11-2013, 01:34 PM   #7
aggieguy13
aggieguy13's Avatar
Local dealers are real nazis as far as what they'll let you swap out. Part of the reason I won't be doing LT's in the bear future. On a side not I guess I'm going to be selling a l VERY lightly used NPP cat back if anyone is intessted. Seeing show the fuse has been pulled since the day I got it the valves are in damn near new condition
