02-10-2016, 10:41 PM | #1 |
Lfx torque/stall converter advice
Hello all! I have a 2013 v6 auto and am looking into torque/stall converters but not sure what would be best for me. I don't daily my car but I do drive it a good bit, if the weather allows it. I have all the typical bolt ons, along with a 100shot of nitrous and a 3.45 LSD swap from an ss. So here is my question. What is the best bang for the buck? I wanna be able to drive the car on a daily basis in the summer and what not, so don't wanna give up drivability but I still wanna improve my 1/4 times and 60ft times. Should I also look into trans coolers? I also want to have it hold up to possible future mods. (Cams, FI, ect) Just trying to get my all my ducks in a row before I buy my tune so any advice is greatly appreciated! Thanks guys!
02-11-2016, 08:49 AM | #2 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I had a FTI 3200 single disc and switched a couple months ago to a Circle D 3800 triple disc. Mine is a daily driver with 81k miles on the car.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-11-2016, 08:50 AM | #3 | |
I had a feeling you to comment on this thread, LOL. So how do you like the circle be compared to your other one? How much is it, if you don't mind me asking Sent from my iPhone using Tapatalk |
02-11-2016, 09:09 AM | #4 |
wasn't cheap, think it was twice the cost of my FTI. Think i paid around $1200, not 100% sure. You are paying for the ability of it to lock up under WOT where as the FTI cannot. Something funky has been with my setup. Tried many many tunes and still having an issue keeping it locked. Not saying its an issue with the converter, just in my trans or tune or both. Been through a lot of miles and abuse!
02-11-2016, 09:13 AM | #5 | |
I see. That's a bit pricey for what I initially intended. I think I might look into an FTI and try that for my "first" converter. How is the install? Does FTI make a 3800? And should I also look into a trans cooler? Thanks again for the help Sent from my iPhone using Tapatalk |
02-11-2016, 09:18 AM | #6 |
yes they make a 3800. Get a good cooler and consider doing what some of us have recently done by getting a thermostat for it. I have mine routed to flow through the radiator only til it reaches a certain temp then it will flow through both cooler and radiator. I did this cause i noticed my trans fluid temps were very cold even after driving an hour. I am using the B&M HiTec cooler. Doesn't have to be too large as most are very efficient. The way the T stats are designed, 90% flow goes through the cooler by pass and 10% flows through the cooler to keep the system pressurized and when gets to temp, 100% flows to cooler
02-11-2016, 09:41 AM | #7 | |
Thank you for the advice. I will look into all of that before deciding. Did you just get a gauge for a pillar pod? Sent from my iPhone using Tapatalk |
02-11-2016, 10:13 AM | #8 |
Gauge for what? Trans temp? I monitor it with my HP Tuners logging. Plus my car is a RS so it has the console gauges too.
02-11-2016, 11:51 AM | #9 |
Drives: 00 Trans Am Join Date: May 2014
Skullcandy, we also have an HP series 245mm torque converter for your LFX. It features an oversized 258mm single billet lockup piston, furnace brazed pump and turbine, hand TIG welded fins and your choice of stall speed. Price on these is $550. Give us a call if interested.
-Brian |
02-11-2016, 03:49 PM | #10 | |
Got confused when you said thermostat, been a long day already haha. I have a trans temp gauge so I'm good for that. What size torque converter is "to much"? Not familiar with all this quiet yet. Is there a threat to the life of the trans? Sent from my iPhone using Tapatalk |
02-11-2016, 03:50 PM | #11 | |
Thank you! I will be calling soon and getting everything I need before summer rolls around! Just don't wanna break the bank lol. Sent from my iPhone using Tapatalk |
02-11-2016, 05:01 PM | #12 |
3400-3800 rpm range will make u happy.
This is the tstat I bought http://www.amazon.com/gp/aw/s/ref=is...efix=derale+th Some went with this one http://www.improvedracing.com/oil-th...65f-p-423.html
