06-15-2017, 02:24 PM | #1 |
Drives: 2010 Camaro SS Join Date: Dec 2006
ZL1 differential swap - my 3.23 for your 3.73
EDIT: NO LONGER LOOKING. FOUND A TRADE. CLOSE THREAD.
So I've got a 3.23 ZL1 diff that I swapped into my SS. I now wish I would have gone with the 3.73. Thinking about changing out gears...but wanted to see if maybe someone was interested in just swapping their 3.73 for a 3.23. I know some higher powered ZL1 manual's have benefited at the strip by switching out to a 3.23. I'm located in the Minneapolis MN area. Last edited by cc-rider; 09-11-2017 at 10:08 PM. |
06-17-2017, 02:30 PM | #2 |
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
what bushings are you running?
"J.Sick"
2010 Camaro 2SS |
06-17-2017, 08:20 PM | #3 |
Stock ZL1 bushings in the diff.
06-21-2017, 12:22 AM | #4 | |
Drives: 2010 camaro ss/rs Join Date: Dec 2009
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads ProCharger F1-X Nitrous Outlet Direct Port Fore Innovations Triple Pump on E85 Alky Control Meth Injection ProEFI ECU Stainless Works 2" Headers with Corsa 3" Exhaust RPM 4l80e with Jakes Transbrake BMR Everything with 15" Conversion Zl1 Front Brakes & Carlyle Racing Rear Brake Kit Weld Wheels |
06-21-2017, 07:53 AM | #5 |
I really don't know as I bought it used and forgot what the guy said. But it is lower mileage unit. Works perfectly. Just want the 3.73 instead.
06-22-2017, 07:53 PM | #6 |
Here's a couple of pics of the diff right before it went in (Nov 2016). Put it in last year right before winter...got one ride in before the snow hit...parked it until I got it out this May. It has 500 miles on it since then.
07-09-2017, 04:08 PM | #7 |
Bump. Still looking to swap.
07-10-2017, 03:48 AM | #8 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I wish you were closer
07-12-2017, 02:49 AM | #9 |
Drives: Camaro SS Join Date: May 2015
I have RPM 3.91 diff with DSS1400hp axles let me know if you are interested
2012 LS3, ERL 416ci, Squash dual fuel system, procharger F1A cog race kit.
07-24-2017, 05:57 PM | #10 |
Bump. Still looking.
08-19-2017, 10:01 PM | #11 |
And another bump.
08-26-2017, 11:51 PM | #12 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
pm sent
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
09-11-2017, 10:06 PM | #13 |
Done deal. Thanks to miller8907 for the trade!
