02-05-2020, 10:22 AM | #1 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
To e85 or not to e85 for street application.
Contemplating if spending 1500-2000$ is worth it to do e85, only to gain an avg of 30-50 hp/trq (maybe more) on street application. I know it has the benefits......BUT is it worth it dollar per HP.
02-05-2020, 10:37 AM | #2 |
Drives: All things Turbocharged Join Date: Dec 2010
A lot more than 30-50 to be gained.
If E85 is available around you, for sure give yourself the option. |
02-05-2020, 10:50 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Depends on what mods you have and how much your engine will handle. If you're at say 700WHP FI adding E85 you could add more than 50hp but if SBE.. well..... What are the ultimate plans. Wouldn't be worth it to me even if it was available until I forge the bottom end, then I would do it IF I had it around me because the engine could take the power.
02-05-2020, 10:57 AM | #4 |
Camaro Super Fan
Drives: 2019 Chevy Camaro Join Date: Feb 2020
hmmm
the price we pay for that little bit of added horsepower and torque. It's expensive, ight? |
02-05-2020, 11:27 AM | #5 |
How much do you pay for a cam job? How about some name brand headers? Seems to me that the cost to allow for the use of E85 is right in line with the typical mods, and you stand to reap higher gains.
Just my thoughts on the matter. -Scott |
02-05-2020, 01:04 PM | #6 |
Drives: it changes Join Date: Nov 2010
Without knowing exactly where you are now....nobody can even start to suggest if you will see gains etc
02-05-2020, 01:25 PM | #7 |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
I personally think more important than the HP gains is the reduced likelihood of pre-detonation. If probably tuned you are providing the engine a little bit more protection.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
02-05-2020, 02:03 PM | #8 |
Drives: 2010 RS/SS Join Date: Dec 2010
If it's readily available in your area, then yes it's worth it in my opinion. It's usually good for a least 50hp or so.
02-05-2020, 04:38 PM | #9 | |
02-05-2020, 04:45 PM | #10 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
If you talk with some of the vendors here you might find an AGP dual pump kit isn't that much more... and will support 1000 on E. I wouldnt let 93 octane come near my car anymore. I can't.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-05-2020, 05:24 PM | #11 |
I do, every time I drive it. It's no big deal.
Although looking to do a 50/50 mix some time this year to try |
02-05-2020, 05:51 PM | #12 |
BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
I get 660/579 without and 787/675 with E85
What else can I do to my Camaro?
02-05-2020, 06:18 PM | #13 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Is it true with the e85 kit and a tune you can switch as needed between e85 and 93? Feel like in the winter I would use 93 since it’s my daily driver.
02-05-2020, 06:21 PM | #14 | ||||||
All in all with Centri, Wideband/boost gauge, flex fuel sensor, aux pump, 127# injectors, wires, plugs, labor, tune... 10,100$ With out e85, and aux fuel, flex sensor... around 8500$/8600$ |
