11-12-2014, 10:35 PM | #1 |
Drives: 2010 Camaro 2SS RS M6 SIM Join Date: Nov 2009
Shifter question..
I have a 2010 SS LS3 and 3 years ago I swapt out the stock shifter for A MGW shifter Well, I've since developed some bad wrist arthritis and have had surgery. The MGW shifter is chunky and is becoming difficult and painful to drive due to my condition. Does anyone know of a smooth after market shifter for the SS? I like the stock ZL1 shifter, maybe someone has driven that and could give me some feedback on feel? Any other ideas would be greatly appriciated.
Thanks.
Four Horsemen
11-12-2014, 11:27 PM | #2 |
Drives: 2013 Camaro LS Join Date: Sep 2014
Get Automatic
11-12-2014, 11:46 PM | #3 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
Try a weighted ball on it. Maybe a different style knob
2011 2SS/RS built 8/24/10
11-12-2014, 11:51 PM | #4 |
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
I put a Hurst on my 2011 and it was like your present shifter. The factory ZL1 shifter is very smooth. I don't think I would change it even if someone gave me an aftermarket shifter.
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
11-13-2014, 05:58 AM | #5 |
11-13-2014, 08:05 AM | #6 |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
It's more of a notchy tranny in my car than the actual shifter. 2nd gear grind unless hot but still notchy
11-13-2014, 09:37 AM | #7 | |
Does the Zl1 still feel notchy? ( not sure if the ZL1 and SS share the same tranny) How is the zl1 throw compared to the hurst? Thank you.
Four Horsemen
11-13-2014, 09:40 AM | #8 |
Do you have the ZL1 shifter in your car? I'm a little worried it's just the way tranny in the SS is.
Four Horsemen
11-13-2014, 10:17 AM | #9 |
It is the way the trany is. Research in the transmission forum
11-13-2014, 11:00 AM | #10 | |
Drives: 1LE Join Date: Feb 2013
As for the throws, both the ZL1/1LE throw and the upgraded factory short throw shifter have a 22% reduction over the standard SS shifter. The MGW is a 33% reduction over the standard SS shifter, and the Hurst is a 44% reduction. Frankly, if the MGW is bothering you physically, you might consider just putting the stock shifter back in. Generally, the shorter the throw, the more physical force needed. So, the factory standard shifter will be sloppier but, in theory, easier to negotiate. |
11-13-2014, 11:13 AM | #11 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
OP, when I changed the transmission fluid to Redline D4 AFT, the shifting became so much smoother. I know that we have different transmissions, but that may be something to look into.
11-13-2014, 12:09 PM | #12 | |
Lets roll...
Drives: 14' Join Date: Jun 2014
OP,
I totally agree with the guy below. I think you should either go back to stock or with the 1LE/ZL1 shifter (best compromise between shorter throws and overal smooth effortless operation). I absolutely love the way my 1le shifter feels compared to all the other aftermarket shortshifters I have had in previous performance cars. Alcantara knob an all. Quote:
11-13-2014, 09:02 PM | #13 | |
I also agree that a longer shift lever gives more leverage and is easier to shift. I learned that after I put a short shift lever on a hurst shifter in a 4th gen.
11-13-2014, 09:55 PM | #14 |
Drives: 2012 LS3 SS 6M Join Date: Oct 2014
I have a stock Hurst short shifter if your interested. Came off my 12 SS.
K&N Thyphoon CAI HURST Billet/Plus Short Throw |
