Old 06-08-2014, 12:45 PM   #1
jph2275
jph2275's Avatar
Drives: 2010 Camaro 2SS/RS CGM
"Flowtie" for my heritage grill and beer for my horses
The former anyway ... Need not waste beer
Hello camaro5,
I have been rocking a heritage grill on my 2010 camaro since 2011. I have enjoyed the stealth look but recently I've gotten tired of it looking so ... plain. I looked into an SS emblem for the grill but couldn't see spending another $150 or so like I did for the trunk emblem. And THEN to complicate matters further GM came out with that trick looking flowtie. Ugh.
So I was cleaning out the attic the other day and found my stock grill with my stock bowtie. I thought grill, bowtie ... I've gotta go order a flowtie!!! After finding no such luck on the forums I decided to go with plan B and make one. It fit well anyway, because my natural cheapness outweighs my natural laziness. I figured I could do the project on the cheap ...
So I began planning
Step 1:
Get bowtie,
Step 2:
Get vice, Dremel (from my first GI Joe lunch box), cutting and sanding bits for Dremel, metal file, sandpaper, plastic grade primer paint and clear coat. Also glue (I used gorilla glue) and speed nuts from the parts store.
Step 3:
Take a deep breathe and begin cutting. I followed the inner outline of the yellow portion of the bowtie just in case the Dremel jumped and cut the outer chrome portion. This took time and patience (also like a goof I didn't realize the yellow part came out so anyone trying this may just remove this from the get go). I outlined the bowtie area by area and was eventually able to pop the pieces of it out. Make sure to save the rear clips from your trimmings! You will need them!
Step 4:
Sand out the inner portion with a Dremel sanding bit. I also used a sanding bit that was "cone shaped" for the deeper areas. For the corners and flat areas I worked a metal file to maintain the integrity of the points.
Step 5:
Sand with a medium grade sandpaper until your bowtie looks brushed. Make sure to get deep into all of the corners do the paint will adhere.
Step 6:
Prime and paint. I did about 3-4 coats of each product with 3 coats of clear
Step 7:
Taking the original larger clips from the bowtie trimmings, shave any excess plastic off and sand them so that they will adhere to the glue. Glue the clips to the rear upper frame of the bowtie as pictured. Make sure the side with the extra notch on it is facing downward. I used clothes pins to hold them while they dried.
Step 8:
Using your speed clips with the flat side on top and clipped side on bottom attach the bowtie to the heritage grill on one of the slots. Mine held very tightly and when I tried to remove moved the whole bumper so it seems very tight. I used 3/8" speed nuts and widened the mouth ever so slightly with needle nosed pliers. Credits to our1stcamaro for the third photo of the rear (different bowtie same idea).
Step 9:
Enjoy your DIY "flowtie."
This project took me several days as I have work children and no wife (thank god). I really like it and am glad to have taken the risk of chopping up a perfectly good bowtie. I had not seen one done this way so I thought I'd share. And yes I know, a parking lot in Austin did work on my license plate ... That's next to fix ...
Peace,
Pat
Pat
2010 2SS/RS M6
Originally Posted by HDRDTD View Post
As long as it has enough horsepower, I don't really care if it's a 4, a 6, an 8, or a 10.
And I don't really car how they make the horsepower, whether it a Turbo, supercharged or just a whole lot of hamsters.
3.91's, TSP Longtubes, SWG Tune, Vararam, and a heavy foot
jph2275 is offline   Reply With Quote
Old 06-08-2014, 12:52 PM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
cool
JCunningham is offline   Reply With Quote
Old 06-08-2014, 12:58 PM   #3
SSpartan117
Drives: 2012 Camaro 2ss/rs
Looks nice bro!
SSpartan117 is offline   Reply With Quote
Old 06-08-2014, 01:03 PM   #4
ratfinkharley
ratfinkharley's Avatar
Drives: 15 JKU, 00 S10, 73 Vette, 12 JK
Nice work.
I hope you had your children involved in the project. It is great to hand down some good ole fashioned ingenuity.
RotoFab CAI - VMaxx Ported TB - Apex Catch Can - CFD Shifter - Choppers Inc Loaded Dice Shift Knob
ratfinkharley is offline   Reply With Quote
Old 06-08-2014, 01:44 PM   #5
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
Front emblem comes like that on new z28
joes407 is offline   Reply With Quote
Old 06-08-2014, 01:51 PM   #6
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Good job and it looks great.
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 06-08-2014, 02:14 PM   #7
sdmaro
Drives: 2011 LS Camaro
This inspired me to do this and put it where the rear emblem is!
Exhaust: Magnaflow catback/x-pipe, Injen SRI, BBK Headers w/ no cats
Suspension: BC BR Coilovers
Cosmetics: ZL1 front conversion, AAC plasma afterburners 2.0, GFX rear,
Interior: AAC red footwells, ZL1 shifter boot/knob, suede center console
sdmaro is offline   Reply With Quote
Old 06-08-2014, 02:22 PM   #8
nitto85
Caffeine Injected
Drives: 13 Ram - 05 Widebody 1050rwhp Vette
If its flush against the body I could see where trash/dirt and water could get stuck in there. I don't think I would do that.
nitto85 is offline   Reply With Quote
Old 06-08-2014, 04:38 PM   #9
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
I had my doubts after looking at the second and third pics, but it turned out very nice.
JR 1 is offline   Reply With Quote
Old 06-08-2014, 04:53 PM   #10
Camarolover85
Drives: 2019 Dodge Challenger Scat Pack
Lol! Me too, turned out cool though
Camarolover85 is offline   Reply With Quote
Old 06-08-2014, 04:59 PM   #11
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
Awesome! Looks great, good job!
SPARTAN sui is offline   Reply With Quote
Old 06-08-2014, 05:40 PM   #12
Muscle Car Lover
Muscle Car Lover's Avatar
Drives: 2014 2SS M6 "CHRISTINE"
Great work! Came out awesome.
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my king–from this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning
Muscle Car Lover is offline   Reply With Quote
Old 06-08-2014, 05:41 PM   #13
homewrecker
homewrecker's Avatar
Drives: '04 Z06, '14BMW M235i, '15 SS/1LE
Some talented people in this forum!
Sent from my LG-LS995 using Tapatalk
homewrecker is offline   Reply With Quote
Old 06-08-2014, 06:27 PM   #14
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
That's why he called it a DIY FloTie..
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune...
ToolFan66 is offline   Reply With Quote
