11-03-2014, 08:26 PM | #1 |
Drives: 2011 cyber grey metallic camaro v6 Join Date: Jun 2011
v6 LLT intake isolator
Brand new aluminum intake isolator that will fit on the LLT engines. Helps keep your intake air temps cooler and is also able to be tapped for extra injectors if needed. Looking to get $100 originally $200.
2011 camaro v6- sts turbo w/ meth injection, barton short throw, spec stage 3+ clutch, forgestar f-14 rims, Nitto invo tires, pfadt sway bars drop springs and end links, rx catch can, goodridge stainless steel brake lines, aac halos afterburner taillights and sidemarkers, sebon carbon rear diffuser.
11-03-2014, 09:06 PM | #2 |
Drives: 2004 Join Date: Jul 2014
Are you sure works on the v6, lfx the wholes are different!
11-04-2014, 04:55 AM | #3 |
Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
Yeah you might want to double check that the LFX and LLT are
Different |
11-04-2014, 07:41 PM | #4 |
Yea the ports are different so this one will fit better on the llt engine Jason makes a different one for the lfx.
11-04-2014, 07:45 PM | #5 |
