Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 09-29-2016, 10:45 PM   #1
SSmokinSS
Get Some
SSmokinSS's Avatar
Drives: 2014 ZL1 6Speed
Drag setup (18")
I recently got a set of rear ZL1 replica 18x11's with 325/40R18 M&H Drag radials. I am running the stock 20" fronts with 285's.
I want to go with a semi skinny in the front and keep the stock look. I have seen an 18x8 ZL1 replica, but I'm sure they wont clear the brakes.
Any options out there?
SSmokinSS is offline   Reply With Quote
Old 09-30-2016, 07:22 PM   #2
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
You could get the 20x8 replica and run a narrower tire.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 10-12-2016, 09:24 PM   #3
SSmokinSS
Get Some
SSmokinSS's Avatar
I'd like to go with an 18 to match the rear. Has anyone modded the 18x8 to clear the brembos?
Old 10-12-2016, 10:01 PM   #4
macSS
macSS's Avatar
Drives: 2012 SS Camaro LS3
As far as I remember the 18x8 from factory reproductions will clear the Brembos just like the rear
2012 Ashen Grey LS3_ARH 1 7/8 Long tubes_Pypes Exhaust Axle Back_C.A.I._
Bo White Ported Throttle Body_Custom Black Anodized Fuel Rails_3:91 Rear
ARP Stainless Bolts_MSD Wires_Elite Engineering Catch Can_MGW Flat Stick_Stewart Warner Pro Gauges_BMR Rear Suspension_ZL1 Rear Swaybar
427 HP To The Wheels_Tuned and Dyno'd by ECS
macSS is offline   Reply With Quote
Old 10-12-2016, 10:18 PM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
My 18 x 8 Welds just barely cleared and would rub on some turns and bumps.
Old 10-12-2016, 10:57 PM   #6
SSmokinSS
Get Some
SSmokinSS's Avatar
I'm not super familiar with the offset, backspacing game.
The replicas I found that I like, come in 18x8 with either a 19mm or a 27mm offset.
The factory wheels are 20x10 with a 23mm offset.
With the wheel being 2 inches narrower, and the offset measured from center, will the 27mm give me more room than the factory rim?
Old 10-12-2016, 11:10 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
With mine it was the offset... it was the wheel diameter of 18". Sort of depends on where the barrel of the wheel lips up to the center piece. Weld did it on the outside so the tires could be reverse mounted. This took up an inch of circumference where as the same size wheel in Forgeline fit perfectly due to the step up happening in the center of the wheel.
I'm sure someone has tried the 18" replicas and will chime in.
Old 10-22-2016, 08:29 AM   #8
sef6
sef6's Avatar
Drives: ZL1 '14, Tahoe '13
Nice setup. What's offset on those 18x11 rear wheels? Thanks for the post.
sef6 is offline   Reply With Quote
Old 10-22-2016, 03:15 PM   #9
wrtowman
wrtowman's Avatar
Drives: 2011 Camaro 1SS
Doug from FR said the 18x8 will clear the front Brembos as long as you do not have the skates on from the stock pads.
Protip: Pm him for pricing. It will be cheaper than ordering through the site.
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
wrtowman is offline   Reply With Quote
Old 10-22-2016, 03:16 PM   #10
wrtowman
wrtowman's Avatar
+43
