11-21-2012, 04:03 PM | #1 |
Drives: 18 Camaro ZL1 1LE (WILSON) Join Date: Jul 2009
Will 1" drop work with SS Factory ground effects
Will Eibach 1" drop springs (pro tour Kit) work with the factory ground effects? Worried about being too low with the ground effects on the car. If anyone has their car lowered 1" and have the factory ground effects I would appreciate comments and maybe some pictures.
11-22-2012, 07:57 AM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Yes, they will work.
You will need to be a little careful parking your car. Some of the higher parking blocks will scrap or hit, but you'll just barely clear most of them. Also, steep driveways need to be approached cautiously. Other than that you should be fine. I'm running SLP Splitter with a 1.0 - 1.5" drop and the only thing I need to be careful of is tall parking blocks. |
11-22-2012, 08:07 AM | #3 | |
