Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - New England
Old 09-27-2013, 04:24 PM   #1
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
ZL1/1LE Tires & Winter Storage
I know there are a bunch of threads on this in other sections, but I was curious what the local NEC5 boys are doing. So, are you guys planning on taking them off to store in the house/basement, using flat-stoppers, pumping to higher pressure, something else, or nothing special?
I was planning on pumping to 40-45 psi and parking on carpet pads in my attached but unheated garage and was curious if anyone did about the same or less last year and had no cracking problems.
bluBlud is offline   Reply With Quote
Old 09-27-2013, 05:16 PM   #2
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
Last winter I pumped mine up to 45 lbs and left it in the heated garage all winter. I keep it at the lowest setting (about 50). Had no issues or flat spots in the spring. Now traction in the cool spring weather is another story.
Happy_Dan is offline   Reply With Quote
Old 09-27-2013, 05:27 PM   #3
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
I also over inflated and left on carpet covered by a sheet of plastic all under the car in an unheated garage. This year they are coming off and the car's going on blocks.
One-Bad-ZL1 is offline   Reply With Quote
Old 09-27-2013, 05:39 PM   #4
FAIRNOT LZ1
It's in black & white
FAIRNOT LZ1's Avatar
Drives: 2012 ZL1 Summit White #1366
Blocked the suspension and left them on, in an unheated garage .... thinking about pulling them and putting them in the basement this year
FAIRNOT ZL1
FAIRNOT LZ1 is offline   Reply With Quote
Old 09-27-2013, 09:21 PM   #5
dkbmx993
Drives: 2010 camaro ss 6spdmanual
I put the zl1 wheel package on in may but i have already gone through a set of tires so i guess I won't worry to much. Ill need new rubber in the spring anyways
dkbmx993 is offline   Reply With Quote
Old 09-28-2013, 12:04 AM   #6
Sunkistcamaro
Sunkistcamaro's Avatar
Drives: 69 Camaro & 2013 Camaro 2SS/RS/1LE
I hate that we have to start thinking about this subject. It's going to kill me to walk past it every day...
2013 IO 2SS/RS 1LE (1 of 95)
Sunkistcamaro is offline   Reply With Quote
Old 09-28-2013, 04:37 AM   #7
scott's45
Scott's45
scott's45's Avatar
Drives: 2012 2SS 45th Anniversary
I pump mine up to 50psi and park on carpet for the winter in an unheated garage. No issues so far. But I've read that you want to keep them away from direct contact with concrete, as the concrete will suck the moisture out of them.
scott's45 is offline   Reply With Quote
Old 09-28-2013, 09:03 AM   #8
One-Bad-ZL1
Those of us with the GY F1's have to watch for damage at 40 degrees and below. There is a bulletin out.
Old 09-29-2013, 07:30 AM   #9
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
drove on them all winter as long as theres no snow
coreyaustin17 is offline   Reply With Quote
Old 10-04-2013, 12:50 PM   #10
Normagene
Normagene's Avatar
Drives: 2013 Ashen Gray M6 ZL1
I got a GM ZL1 Camaro car cover I really don't need or use. Pretty much new, only opened the box and tried it out once just to see how it fit. Anybody looking for one I'll let it go for a $100. Here's a pic, do t remember what they sell for, but I'm sure it's much more than what I'm asking.
Sent from my iPad using Tapatalk - now Free
Normagene is offline   Reply With Quote
Old 10-04-2013, 04:42 PM   #11
One-Bad-ZL1
I'll take it. PM me if I can have it and we'll work out the details
Old 10-04-2013, 05:56 PM   #12
67RS2010SS
67RS2010SS's Avatar
Drives: Maroon 67 rs and CRT 2012 ZL-1
Hope they didn't put that cover on a dirty car or the thing is now contaminated with crap. Your car needs to be basically spotless or the fine swirls and scratches may rear their ugly heads. Which reminds me we need to detail that thing Mr. One Bad!
" No matter how tough you are when a 2 year old hands you a toy phone you answer it"
67RS2010SS is offline   Reply With Quote
Old 10-04-2013, 06:25 PM   #13
One-Bad-ZL1
I know, I'm thinking next weekend maybe?
Old 10-04-2013, 07:53 PM   #14
67RS2010SS
67RS2010SS's Avatar
Let me know I'll check what's going on
