04-25-2016, 08:47 PM | #1 |
Drives: Black aSS 2011 - L99 Join Date: Apr 2012
NOS plate Install.......
Hey Guys,
I have kind of pieced together a nitrous system from various parts makers and it works great. I currently have a fogger nozzle drilled into my intake tube and wanted to go with a plate. Well, I have my plate and it is not a direct fit. With the throttle body being pushed out due to the thickness of the plate, it hits the tensioner pulley for the belt. So YES! I did some searching and I saw one Camaro owner flip the throttle body over so it wouldn't hit. Problem is the plug won't reach over to that side if it is flipped. Anyone got a quick fix for this? I'm checking here first before I start calling around tomorrow.
Staying stock and loving it............
04-26-2016, 01:53 AM | #2 |
Drives: 2015 1SS, 1LE, Recaro, NPP Join Date: Apr 2014
Any reason why you switched to a plate? I'm currently running a single nozzle for my 150 shot. I understand the switch if you're doing a 250 shot, but Nitrous Outlet and multiple other nitrous forums have said it doesn't matter if what you do if you spray less than a 250 shot.
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor) 647 RWHP 723 RWTQ (150 Shot) 12.1 @ 117 (Motor) 11.7 @ 129 (Nitrous) Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports Youtube Channel: Click Here |
04-26-2016, 07:11 AM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I think Nitrous Outlet and maybe Casper Electronics have an extension cable for about $30. Otherwise, break out the colored wire, heat shrink and soldering iron.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-26-2016, 08:35 AM | #4 |
Thank you! I will look in to that.
04-26-2016, 08:37 AM | #5 | |
04-26-2016, 08:38 AM | #6 |
running a 200 shot by the way.
04-26-2016, 08:41 AM | #7 |
here is the best and cheapest one I have found so far. Anyone know of a better or more inexpensive one?
Who is using this one? http://www.nitrousoutlet.com/efi-nit...tput-wire.html
04-26-2016, 12:10 PM | #8 | |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
04-26-2016, 03:22 PM | #9 |
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS Join Date: Jun 2015
Yes you need to flip the throttle body and extend the wiring.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold 2001 Camaro SS SOM M6- sold 1999 Firebird Formula A4- sold |
04-29-2016, 08:19 PM | #10 |
Lingenfelter sells an extension with a tps plug out so you can hook it right up to your controller. Had to use one for my nitrous outlet plate when I flipped the tb.
2010 Camaro 2SS/RS- Airaid Intake, OBX 1 7/8 long tubes, Catless Pipes, Borla X-Pipe, Borla Atak Catback, QTP Cutouts, Nitrous outlet Plate kit with purge, LNC-2000, NOS WOT Window switch, LC-2 Wideband, Autometer Cobalt Nitrous gauge
04-30-2016, 10:57 AM | #11 |
Did you buy the one with the tps wire, or what I am asking is do I NEED the one with the TPS wire?
I'm and 11 L99
05-03-2016, 12:51 PM | #12 |
You don't need the TPS wire unless you are going to connect it to a WOT switch, which is not a bad idea, but not required.
05-03-2016, 01:04 PM | #13 |
My system only activates from the WOT switch, so yes I have one.
05-12-2016, 09:56 AM | #14 |
The TPS signal would go to an Electronic WOT switch that requires a TPS signal. You should have a six wire TPS and I think it's the green (maybe purple, I'd have to look at my bookmarked threads to be sure) wire you tap, but if you are using that type of WOT switch and just a microswitch that is triggered by physical pedal movement, the NO cable might be worth the investment.
