01-16-2014, 11:14 AM | #1 |
Drives: 2010 Aqua Blue Camaro 2SS/RS Join Date: May 2013
what do you guys think about this set up?!
-IPS twin turbo kit
-NGK TR6 spark plugs -ZR1 3bar map sensor -ZL1 fuel pump -82lb injectors -160' thermostat -AEM boost guage -AEM UEGO guage -dual pillar guage pod And this is a run down of what the IPS kit includes -2x Garrett T3/T4 60 Trim Turbos -2 x IPS TIG-welded 304 Stainless-steel Mid Pipes -2 x IPS 3” TIG-welded 304 Stainless-steel Downpipes -2 x TiaL MV-R 44mm Wastegates -1 x TiaL “Q” Blow-off Valve -1 × 4” Aluminum Bar & Plate FMIC Core -1 x IPS Aluminum Intercooler Deflector Shield -1 x Oil Return Pump & Bracket -IPS Oil Feed & Return Line Kit featuring Fragola “Soft” Nylon Braided Hose & --Black Fittings -IPS Sport Crimp Lines & Fittings. These are Mandated in Top-Fuel Racing for the absolute best in quality. No cheap China-bay Fittings Here! -IPS 3” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion -IPS 4” 6061 Aluminum Charge-pipe -K&N Filters -IPS Lower Skid-plate -Windshield Washer Bottle & Accessories -Polished Oil Cap w/oil return Also I will be getting better tires soon after the installation. What tires would you recommend? I wont be driving in the rain or any bad conditions like that. And in May ill probably get trailing arms and bushings.. Shooting for around 620wrhp i know i can easily get way more then that but im going to be running the lowest boost i can get so i dont destroy my motor and/or drive train. Cant wait to get everything and install it! i already bought this stuff and im just waiting for it too ship, so changing parts out isn't possible. To the moderators.. i posted this in the FI section but didn't get much replies, thats whys im posting in general discussion
01-16-2014, 07:37 PM | #2 |
Drives: TT 10' SS -> 16' SS Join Date: Dec 2013
Post some vids when ya get it all done.. this is the kit im getting aswell.
