03-29-2010, 06:46 PM | #1 |
Drives: 2006 Silverado Join Date: Jul 2009
Horn Problem
Purchased Camaro on Metairie, LA but attending USAF Academy in Colorado Springs. When the temperaturestayed below freezing for several days the horn would honk intermittantly when turning or applying pressure to one side of the steering wheel. The local Chevy dealer said it was in the steering column wiring. He removed the fuse as a tempory fix. Took it home for Christmas break and my dealer ordered and replace the wiring. All was fine in Louisiana. Back to USAFA in January and the problem returned and have removed the fuse myself. Anybody else in the colder climates experienced the same problem? If so what was the fix? Any ideas or solutions? This will not be a after graduation in May as I will be stationed at Keesler AFB, Biloxi, MS as my first duty station.
03-29-2010, 07:19 PM | #2 |
Drives: 2018 1LT RS V6 Nightfall Grey Join Date: Jun 2009
Sounds like you have a very horny car....sorry i couldn't help myself, probably just one of those weird electrical problems. Dealer should be able to get it sooner or later, sometimes they go on a wild goose chase til they find the problem. good luck
03-29-2010, 07:30 PM | #3 |
Drives: Audi A4 Cabriolet Join Date: Dec 2008
I rented a Chevy HHR for work with less than 400 miles on it and had the same problem. The horn would honk on its own when making sharp turns or when riding over rough pavement. (Long pissed off honks too) It wasn't cold in Philly so I would also guess electrical. Still it's not a good sign when that starts happening on a brand new car. Good luck.
03-29-2010, 07:55 PM | #4 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
just sounds like the horn wire has a short in it.
03-29-2010, 08:04 PM | #5 |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
Sounds like steering column vibrations are causing the horn to trigger...or it could be wiring getting pinched in the column...which would make me wonder if other wheel controls are activated as well. Horn switch wiring is run in the SIR coil, along with radio controls, etc.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
Similar Threads | ||||
Electronic Throttle Control Problem | Drobcam | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 01-24-2011 01:44 PM |
GM Bulletin HVAC system reprogram caused window problem | VegasSS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 10-09-2009 09:05 AM |
first problem with Camaro | RobH | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 10-05-2009 09:17 PM |
GM Bulletin HVAC system reprogram caused window problem | VegasSS | 5th Gen Camaro SS LS LT General Discussions | 16 | 10-02-2009 02:10 PM |
Somewhat Annoying Back Seat Problem! | ZNOLMT | 5th Gen Camaro SS LS LT General Discussions | 5 | 06-21-2009 09:22 AM |
