06-21-2010, 09:05 PM | #1 |
Drives: '69 SS Convertible Join Date: May 2009
Lets start a list of anyone having issues with 4.10 gears
So it was mentioned from ADM's group that 4.10 gears could possibly break under heavy usage (I assuming mostly with the M6). He recommended staying away from any of the aftermarket 4.10 gears and to go with GM's 3.70 gear.
I want to go 4.10 but not if their is going to be an issue. Especially with the $1,400 installed price tag. So I would like to know if anyone has any first hand experience with 4.10 gear failure or was his an isolated issue?
Build Journal |
06-21-2010, 09:09 PM | #2 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
where are you finding gm 3.70's,, or are you talking about the lingenfelter AAM 3.70's??
06-21-2010, 09:14 PM | #3 |
When I talked to Andy at ADM about gears he uses the GM 3.70 gears. Can't remember if he said 3.70 or 3.73 but I believe Pat's post said 3.70 gears.
Build Journal |
06-21-2010, 09:48 PM | #4 |
there are no gm 3.70's,, nothing you can buy from a gm dealer
richmond gear has 3.73 and 4.10's motive gear has some gears coming out this fall, 3.90 and 4.10?? AAM(the company that makes the camaro rear diff) have 3.70's,, but so far i have not found a AAM dealer that can get them,,, so far the only way i have seen them for sale is from lingenfelter and his dealer network for around $800
06-21-2010, 09:56 PM | #5 |
MURC 666
Drives: 69 Pace Car 68 Camaro Restomod 81 Z Join Date: Jan 2010
What's wrong with Richmonds ?
No issues after 1000 miles and a lot of hard driving . With enough power and abuse anything will break .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it ! |
06-21-2010, 10:33 PM | #6 | ||
Drives: Black SS Join Date: Apr 2010
06-22-2010, 05:05 AM | #7 |
There haven't been any wide spread breakages but I have heard about three. All three of those occurred either at the drag strip or when the driver admitted they were placing the drive train under extreme load on the street (I think you know what I mean). Can you break them with enough power and abuse, of course. Rear ends going the way of the hand grenade has been happening since the dawn of automotive history, I just watched it happen on Pinks the other night. Does the average Joe have much to worry about? No.
06-22-2010, 07:29 AM | #8 |
The rears in these cars are infinitely stronger then the 10 bolts in the last generation. Add 400+rwhp to 4000 pounds of fat pig, throw in M6 shock and traction and it's unsurprising that the pinions are exploding. Problem is, properly (tightly) set-up, the 4.10s are going to make noise. A lot of people don't like that, so compromise is made and the gears are setup slightly looser and you lose tooth engagement. Another issue is pumpkin flex, and hopefully that will be addressed sometime in the future. While the new gears have less teeth, so the bulk of the gear is smaller, they aren't a finer pitch tooth then the factory pinion and are not less strong because of this (the teeth themselves). It's also possible that the first batch of richmonds had an improper heat treat causing issues, it's hard to say without an up close examination, but blaming breakage on the fact that they're 4.10s is blasphemy. It is not a 'weaker' gearset.
06-22-2010, 10:36 AM | #9 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
I've had my 4.10's for about 2000 miles now. No problems or whining. When you go around launching the car hard, especially with high HP mods and DR's, your chances of breaking something go up tremendously. I just don't understand abusing your car like that, take it easy. Slip the clutch, go with a roll out start. I love my car, I'll pull her hair, but I won't bitch slap her.
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
06-22-2010, 10:40 AM | #10 |
36.58625, -121.7568
This is the harsh reality.
06-22-2010, 04:32 PM | #11 |
Drives: 2010 SS/RS Join Date: Jun 2010
Im sure Im showing my ignorance here but what gearing does the Corvette have? isnt this the same LS3 motor? are they geared the same way or is this something completely different, like not interchangeable?
06-22-2010, 05:45 PM | #12 | |
Its a pretty typical set up, engine is to the right of the picture with the transmission bolted to the engine followed by a drive shaft that leads to the rear differential at the far left. Here is the Corvette drive train. Again, the engine is at the right of the picture but you notice it doesn't have a transmission bolted to it. It had a "torque tube" that leads back to a transmission/differential unit located towards the rear of the car. Its a different animal all together. Corvettes are geared higher than the Camaro anyways so there would be no gain there even if it was interchangeable. Last edited by Apex Motorsports; 06-22-2010 at 08:08 PM. |
06-22-2010, 07:59 PM | #13 |
i sure hope my camaro doesnt look like that under side pic!
06-22-2010, 08:09 PM | #14 |
Similar Threads | ||||
333 Ways to get kicked out of Walmart (just funny- do not try this at home) | Abygale | Off-topic Discussions | 47 | 04-28-2010 01:20 AM |
Does anyone have an L99 1SS with Automatic Start? | SamIyam | 5th Gen Camaro SS LS LT General Discussions | 29 | 02-25-2010 04:58 PM |
ISSUES with YOUR CAMARO! | JewelZ | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 65 | 10-03-2009 01:45 PM |
Please Think before you post | 35th02ss | Off-topic Discussions | 35 | 08-02-2009 09:38 AM |
Car won't start Related to the battery cable issues but Different | jhmurphy | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 07-12-2009 11:30 AM |
