08-03-2014, 03:58 PM | #1 |
tire pressure....
Pirelli 245/45 103y. my onstar link suggests 36psi. I kind of thought psi should be a bit higher. would welcome any feedback. thanks in advance.
08-03-2014, 04:02 PM | #2 |
Let's go Rangers!
Cold 36psi is correct.
08-03-2014, 04:05 PM | #3 |
thanks ny!! I am allegedly at 31-32 on all tires. on my way to find my gauge right now
08-03-2014, 07:34 PM | #4 |
Amazing how nyrfan came up with that information so fast, isn't it? You can find it too... open the driver's door and look to the right on the door jamb, just above the door latch bracket. As far as I know, every late modelAmerican auto has this information in the same place (or there about).
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
08-03-2014, 08:04 PM | #5 |
Yea 31-32,is on the low side of things.
09-18-2014, 07:31 PM | #6 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
Hi I just got BFG Geforce Sport Comp 2's installed and I notice the tire shop filled them to 33 PSI cold and I see the Camaro wants 36 should I raise the PSI up to that in them? Anyone have these tires & if so what are you set at? Thx, Cam
09-19-2014, 03:45 PM | #7 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I run a little in the high side....37-38. Even on a hot day on the hiway, they only hit 44-45. Tires are 50psi max...I believe.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
09-19-2014, 04:23 PM | #8 | |
Let's go Rangers!
Felix- speeding in my SS/RS |
09-20-2014, 09:26 AM | #9 | |
Cam |
09-21-2014, 05:14 PM | #10 |
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH Join Date: Jan 2014
At this time of year as colder temps arrive, keep in mind that your air pressure will drop 1 psi for every 10F ambient. So it is good practice to set your pressures 1-2 high as AO does. That way, when you get that 40F overnight, your TP is still close to recommended.
Buy one of these: http://www.tirerack.com/accessories/...Tire+Inflation Best $50 you'll ever spend on your car(s). Also remember that "max summer" tires like your Pirelli PZeros are designed to operate above 40 degrees.
Consensus is, by definition, a lack of leadership.
09-24-2014, 10:19 AM | #11 | |
Drives: 2013 Camaro 2LT/RS Join Date: Jul 2013
I run my tires at 37psi and check once per month. Even at 36 my Camaro rides like it's on rocks!! Anyway I just like the 37 psi figure. Mail Clerk |
09-24-2014, 11:27 AM | #12 | |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
10-21-2014, 05:06 PM | #13 |
Drives: 2014 SpringSpecial SS vert Join Date: Aug 2014
21" to 20"
