Old 05-07-2015, 12:25 AM   #1
bluecam805
Team LFX
Drives: 2012 Camaro LS
AC and heater not working properly..?
So my AC blows no cold air now. I have used it on my long trips, 7hrs drives, a few times. But I only have 60k on it.. Is this normal ?
Also my heater barely shoots out hot air anymore either. I noticed this is all happening around the same time.
Also I recently installed an rx catch can and breather
Has this happened to anyone. Ima get an AC recharge soon
2.5" cat- back Magnaflow exhaust w. resonated x pipe, Roto Fab CAI .. .. JL sound system, Halo fog lights, Escort radar, window tint + turn signals
bluecam805 is offline   Reply With Quote
Old 05-08-2015, 12:53 PM   #2
bluecam805
Team LFX
Bump for any ideas ?
Old 05-08-2015, 01:48 PM   #3
Avenging Orange
Avenging Orange's Avatar
Have you checked the coolant level?
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-09-2015, 06:25 PM   #4
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Is the volume of air flow down? Have you checked the cabin air filter?
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 05-10-2015, 05:36 PM   #5
bluecam805
Team LFX
It has nothing to do with the coolant. And yeah it used to blow cold air. Really cold. But it's just warm. And at night it doesn't blow hot hot air
Does anybody know where the lowP line is to recharge it?
Old 05-10-2015, 09:49 PM   #6
bluecam805
Team LFX
But yes. The coolant level is on point
Old 05-10-2015, 09:51 PM   #7
bluecam805
Team LFX
I still need to check the cabin filter. I plan to do so this coming week but has the been the situation with many camaros?
Old 05-10-2015, 10:33 PM   #8
SSNYSTR
SSNYSTR's Avatar
Drives: Black 2011 Camaro 2SS
Is your ambient temperature sensor still working? Does it still show a temperature on your radio? After I got my car back from my wreck, my AC wouldn't blow cold for long at all and come to find out the sensor missing was causing my car to read that it was -40° so it figured it's too cold for AC and would blow warm air only.
SSNYSTR is offline   Reply With Quote
Old 05-10-2015, 11:44 PM   #9
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
Your cooling system is blocked. It could be water pump, Thermo, radiator, heater core, heater motor, block or heads(not likely since your coolant is topped off) or hoses. Something is blocking the system, how does the temp read(water temp)? Normal? Recharge the freon, or what the A/C is using for refrigerant. Not a mechanic but there are some ideas.
Troy
lawman007 is offline   Reply With Quote
Old 05-11-2015, 02:24 AM   #10
bluecam805
Team LFX
Thanks Troy, my water temp has been fine, nothing over heating. And the ambient temperature seems to be spot on, no problems there.
Is the AC recharge line closest to the driver side firewall ??
I figure the low press.line is the only fitting that will fit the conventional connector that comes with the r134 can sold at auto part stores..?
Old 05-11-2015, 04:11 AM   #11
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
Why don't you take it to the dealer service department and have them look at it?
2SSJIM is offline   Reply With Quote
Old 05-11-2015, 09:42 AM   #12
Avenging Orange
Yes, coolant can play roll in issues like yours.....but obviously not in your case. The reason I usually ask this question is because so many dont check their coolant......hell, some dont even know where the damn oil dipstick is! Good luck solving your issue.
Old 05-12-2015, 07:32 PM   #13
bluecam805
Team LFX
I hear ya, coolants good though
Does anybody know where the line is to recharge the ac???
