05-05-2014, 11:35 PM | #1 |
Drives: 2013 Camaro LFX Join Date: Apr 2014
Will I need a tune (Ported throttle body addition
Just finished installing my Solo Cats and my CAI Intake and catch can. Not bad for a days work! I'm thinking about getting a ported throttle body. My question is will I need a tune with these mods in conjunction with the vmax PTB? The car is damn near brand new (2013 2ls) and I would hate to void my bumper to bumper and powertrain warranties.
EDIT GODAMIT I accidentally posted this in the turbo forums, please pretend my thread is in this general region: http://www.camaro5.com/forums/forumdisplay.php?f=148 |
05-06-2014, 01:01 AM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
No tune needed.
05-06-2014, 01:06 PM | #3 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Agreed, no tune needed. Might want to reset your ECU by disconnecting the battery.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
05-06-2014, 01:12 PM | #4 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
Since you posted this in the Forced Induction section you must now buy and install a turbo or supercharger.
05-06-2014, 01:44 PM | #5 |
Or if he has XM radio he has a hand full of tunes.
05-06-2014, 08:27 PM | #6 |
I pulled the trigger on one earlier. GOTTA BRING THE HEAT FOR THE CAMARO RALLY IN STURGIS! And if the gear ratio could be improved on my 2ls I would consider it, Magnum
05-06-2014, 09:39 PM | #7 |
You can get a 3.27 or 3.55 in your differential. Any other ratio or LSD you will need to swap out to a SS differential. I'm going to a 1LE diff with 3.91.
05-06-2014, 09:41 PM | #8 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
The 2LS doesn't accept any gear ratios unless he does a full rear swap
05-06-2014, 10:13 PM | #9 |
If it is the same 7.6" differential as the LT V6 Auto's it can accept some other gears. Richmond does make a 3.55 for the 7.6", and GM makes 3.27.
Thread Tools | |
