#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
AWE Tuning
Old 08-02-2018, 11:23 AM   #1
jcor3
Drives: 2018 2SS & 2002 1500HD
Rear Diff Groan 2018
2018 2SS with Mag Ride, NPP, auto trans
I picked up the car May 23 and have driven 7500 miles. I started to hear the rear differential groan on cold turns a few weeks ago. Talked to the dealer and was given the typical bs, normal, bring it in, no bulletin on the 2018, etc.
Yesterday the car was in for my free oil change. I listed exactly what the problem was on the online scheduler. The service intake guy tried to change what I had listed. Anyway, took the technician for a drive and couldn't duplicate due to the dealer being 40 miles from home and the car was warm.
They let the car sit until lunch and were then able to reproduce the differential groan.
Get this: There is no fix. (Even though there was a fluid flush service bulletin on the 2017 and 2016's) My car is now an official GM guinea pig.
"PEI0465: "Engineering Information - Cold Moan from Rear Differential on Vehicles that Have Never Had a Rear Differential Flush (May 29, 2018)"
GM wants data, said another way, they are tracking my car now they will know how long it takes for the differential to fail.
The Engineering INfo doc states clearly that the tech was supposed to call the engineers with the phone numbers listed and document that on the customer file. No surprise there is no such record on my docs.
To the point, I bought a car for nearly $50k that sounds like the rear end is going to fall apart every morning. GM knows about it and doesn't give a shit, and they are clearly hoping to stall me until the warranty expires. BTW, the warranty will expire the day before the diff does....
jcor3 is offline   Reply With Quote
Old 08-02-2018, 09:43 PM   #2
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
Dealers are flushing or replacing the diff. That's the fix. Leave that crappy dealer and go to another one.
torqueaddict is offline   Reply With Quote
Old 08-03-2018, 11:47 PM   #3
camaro5's Avatar
Drives: X-15 Velocipede
Put some Amsoil gear oil in with a bottle of lsd additive
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 08-04-2018, 08:45 AM   #4
len_eng
Drives: 2024 Radiant Red 2SS, 1994 Z28,
I had the same issue and brought it in this week. The receipt states that there was a TSB #17-NA-287 that covered the issue and they replaced the gear oil.
len_eng is offline   Reply With Quote
Old 08-21-2018, 06:01 PM   #5
Marco Falcone
Marco Falcone's Avatar
Drives: 2018 2SS Convertible MBM/Kal
My 2018 2SS Vert has the RD groan. Started at maybe 1800 miles. Thought it was a tire issue. Then it went away, Now with about 2700 miles on the car, it’s back. Only when the car has been parked overnight/several hours and is cold. Goes away after a few minutes/few turns.
I went to my dealer. Told the Service Manager Greg about it. He said it happened on some of the Camaro’s and Vette’s, but it was not common. He said he was aware of a TSB about it and told me to bring it in whenever was convenient and they would flush and refill it, under warranty and the TSB. (I told him which one, 17-NA-287.) He punched some keys on his computer and said that was the right one. He added it would be documented in my service file in case there were any other problems after the service. I made an appointment for this coming Thursday. He said they would try and get it done in an hour or so.
Hopefully this will solve the issue.
Really happy with my dealership so far. No argument, no discussion. Just “Yes it can be a problem, sorry we will fix it at your convenience.”
Same attitude as when I asked for them to install a Dimple magnetic oil plug on delivery. (SM: “Good idea. I use those, too.”). And when I came in for my first free oil change at 500 miles. (SM: “No prob. I wish more people knew how to take of a new performance car.”)
Hopefully the dealership stays this way!
2018 2SS Vert. MBM/Kalahari. MRR FS01’s with 285/305 MPS4S. Black Bow ties, A8, MRC, NPP, 6-piston Brembo’s w/ matching rears, OEM Ground Effects/Splash Guards, 8”/Nav. Borla S-type, Pray IM/TB, RotoFab.
Past DD’s of note:
2013 Caprice PPV. (“Company” car.)
1998 Cadillac STS
1996 Impala SS
1969 Cadillac DeVille Convertible
1993 Corvette
1991 Mustang 5.0 LX
1973 Alfa Romeo Spider
1986 Mustang GT T-top
1964 Falcon Sprint Hardtop. (First car, still have the key!)
Marco Falcone is offline   Reply With Quote
Old 08-21-2018, 07:51 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
This one of those subjective problems. Some groan is inevitable in a cold limited slip differential, but how much is too much?
If it happens only when cold and there's not thumping or snapping, I would not get bent out of shape if a flush doesn't fix it or if it come back soon after a flush. That would be an indication that you are too sensitive to a normal feature of this device.
Rock-It Man is offline   Reply With Quote
Old 08-21-2018, 07:58 PM   #7
Gunmetalmissle
Drives: 16 ngm ss
Long story short my diff had cold morning groan. I just recently replaced it with leftover fluid I had from my G8 GT. If you are not familiar with the G8 fluid it is the super expensive Castrol carbon mod saf. Three mornings in a row I have been groan free. I need to drive it a few hundred more miles before making a definitive conclusion but so far it seems to have fixed the problem.
Gunmetalmissle is offline   Reply With Quote
Old 08-26-2018, 01:39 PM   #8
aldaran
aldaran's Avatar
Drives: 2016 Camaro 2SS/RS
Mine has it, but only on cool mornings, but I don't hear any thumping that would indicate any issues. My commute is 10 miles and don't hear it anymore after that first turn in the morning.
2016 2SS: Silver Ice, A8 Auto, Adrenaline Red, Black Rally Stripes, and Black bowties.
My Journey.....
1100 Status - 08/17/2015 : 2000 Status - 09/28/2015
2500 Status - 09/29/2015 : 3000 Status - 09/29/2015
3000 Status - 10/19/2015 TPW 11/9
3800 Status - 11/04/2015 Seq: 122808
4300 Status - 12/17/2015 (Charlotte, MI)
4200 Status - 01/08/2016
4800 Status - 01/14/2016
5000 Status - 01/19/2016
6000 Status - 01/20/2016
aldaran is offline   Reply With Quote
Old 09-11-2018, 11:22 AM   #9
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
My 2018 2SS is now starting to make this groaning noise :( any word if GM finally got a TSB for this issue for the 2018’s yet? Also to everyone here that has gotten this issue resolved, how has your diff acting?
Azerlazer26 is offline   Reply With Quote
Old 09-11-2018, 12:13 PM   #10
torqueaddict
I'm assuming the weather temps there are starting to dip? Seems to be more of a cold climate issue. Sucks that it happened on your 2018. What's your mileage?
Old 09-11-2018, 12:27 PM   #11
VinnAY
Drives: 18 1SS/1LE
I haven't noticed any of this on my car, so far...Mar 18 build date. I don't if I'm usually on the throttle enough with the exhaust in Track Mode to disguise any minor noises.
VinnAY is offline   Reply With Quote
Old 09-11-2018, 01:01 PM   #12
Azerlazer26
Just about to cross 4,600
Old 09-11-2018, 01:03 PM   #13
Azerlazer26
I’m always on the trottle and have my exhaust set in track just so I can hear those aggressive pops from a cold start. I hope it’s just the diff fluid causing this issue.
Old 09-11-2018, 01:15 PM   #14
Wyzz Kydd
Banned
Drives: 2018 Camaro SS1 1LE
My 2016 SS had it. I took it in, they changed the diff fluid and I drove it for another 30K + miles with no groaning.
Wyzz Kydd is offline   Reply With Quote
