12-23-2009, 08:08 PM | #1 |
Drives: O2 GMC & 2010 camaro SS IBM 6M Join Date: Sep 2009
vibration/chatter problem
I have a M6 2SS. when i take off in first i let out the clutch and i hear a vibrating/rattling noise. 50% of the time it does it and its when im taking off in first gear. it happens at the last second of letting out the clutch and sometimes carries on a couple short seconds after fully letting off the clutch. and it does it in second and third but not as much! Its only at low rpms as far as I noticed. Also the times its happened is more on first take off after startup.
i had a friend ride with me who has messed with older f-bodies for years, but never new camaros, say it sounds like a heat shield rattle. I searched many forums and found some say the driveshaft needs a spacer or washer/ some say its something in the IRS when the car is going slow and under a load. I also noticed today that when im slowly accelerating while turning sharply like in a parking lot it does it. I feel the chatter through my clutch more than my shifter. kinda in the floor boards too. how people say its a spring issue in the clutch it shouldnt be that because the clutch is hydraulic and isnt a direct linkage type connection to the transmission so i what im feeling shouldnt be that right? (kinda new to the setup of the new camaro so correct me if thats not right). I dont know why whatever the noise is i feel it more in the clutch pedal and it does it when im letting out the clutch but dont feel it in the gas pedal or shifter. Any help would be appreciated so that when i suck it up and let a dealer look at it i have some ideas to throw at him. That way they dont have my baby in pieces trying to figure it out! Thanks for any replies
2010 camaro SS/RS Manual IBM. NEW TIME 12.24 @ 114 mph. -[B] street tires, Hurst short throw, Halltech yellow jacket intake, AR long tube 1 7/8 headers, and a tune. 12.82 @ 110 MPH 1.92 60ft ALMOST Bone Stock ONLY MOD IS Borla mufflers. |
12-23-2009, 09:39 PM | #2 |
Drives: 10 Camaro/69 Bronco/08 Mazda3 Join Date: Jul 2009
Take it to the dealer and take a service rep for a ride if it is repeatable. If you're not sure about your dealers competence, find another one. Sounds like something is loose or came loose if it wasn't doing that from the dealer. Anytime something comes loose, that's not a good thing...
No funny stuff from my 1SS M6... only the gurgle in the heater core, which I don't care about.
Selection Worksheet - 04/27/09
3300 - 08/03/09 6000 - 08/25/09 VIN# 34612 Bitchin Camaro - Dead Milkmen - http://www.newgrounds.com/portal/view/8092 Thank You Oshawa - Domo arigato Mr. Roboto ~1600 mi so far - 07/18/10 |
12-24-2009, 07:51 AM | #3 |
Drives: 2010 camaro rs/ss 67 camaro Join Date: Aug 2009
It could be a heat shield or a rubber muffler hanger has come loose.
12-24-2009, 07:58 AM | #4 |
Drives: Camaro GT Join Date: Dec 2009
My M6 2SS does this as well and I've isolated the noise to the rear of the vehicle. Does your trunk latch ever not catch when closing your trunk? I'm thinking its either the hardware that mounts the OEM spoiler or the heat shield at the rear of the car. Its just pot metal that is bolted directly to the tub with nothing by way of damping between it. The rattle is even more noticable since I installed racing headers/exhaust... I'm thinking about ripping out the crap heat shield and installing thermotec heat shield. Thermotec would dampen the exhaust note reverb'ing thru the interior and would dissapate heat better than the OEM heat shield!
12-24-2009, 11:46 AM | #5 |
Unless I overlooked the clutch in the trunk of my Camaro next to the battery I'm gonna say the particular rattle coming from the back of my car is not the clutch plate
Similar Threads | ||||
GM Bulletin HVAC system reprogram caused window problem | VegasSS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 10-09-2009 09:05 AM |
first problem with Camaro | RobH | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 10-05-2009 09:17 PM |
GM Bulletin HVAC system reprogram caused window problem | VegasSS | 5th Gen Camaro SS LS LT General Discussions | 16 | 10-02-2009 02:10 PM |
pm problem | drivingincamaro | Site Related Announcements / Suggestions / Feedback / Questions | 4 | 06-23-2009 10:20 PM |
Somewhat Annoying Back Seat Problem! | ZNOLMT | 5th Gen Camaro SS LS LT General Discussions | 5 | 06-21-2009 09:22 AM |
