Old 07-30-2013, 11:05 PM   #1
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
ZL1 FPCM????
Checking to see if anyone knows 100% sure if the 1LE has the ZL1 FPCM? I know it has the ZL1 pump but curious about the module. I"ve got the SLP TVS2300, ID850 injectors and LS9 cam installed with Dynotech headers, all from Jannetty, and Ted says my fuel pressure dropping off in the datalogs on the upper end. This is the last thing I expected since it has the ZL1 pump. Air fuel is perfect across the board also. Anyone else run into this? Appreciate any info. Thanks
white1LE is offline   Reply With Quote
Old 07-31-2013, 10:20 AM   #2
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
put a ADM fpcm in it. easy answer.
-John S.
Old 07-31-2013, 03:14 PM   #3
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2012 SIM 2SS/RS & z71
Can you validate the pump is truly a ZL1 pump without dropping the tank or drilling any holes?
Or it may be easier to compare part numbers on the FPCM. Remove back seat and passenger panel to access it.
*edit*
Upon further review, two GM parts sites list the fuel system module as if it's the same for all models (v6 - LSA)
Mechanical Catalog - 2013 - Chevrolet - CAMARO
fuel system, fuel supply, control module Camaro All
Assuming that's right, and you have the expected pump then ADM controller seems like the next logical step.
Southern Comfort is offline   Reply With Quote
Old 07-31-2013, 09:46 PM   #4
white1LE
white1LE's Avatar
Ordered from ADM today. Thanks Andy!! I work at a Chevy dealership in parts and service, so I did compare part numbers. The pumps are the same in both ZL1 and 1LE, the FPCM does have the same part number across the board as stated by Southern Comfort but different programming for each car, v6 to ZL1.
Thanks fellas!!!
