Old 12-19-2014, 06:51 AM   #1
L99CAMA2011
L99CAMA2011's Avatar
P0306 Code and Service stabilitrac
P0306 Code and Service stabilitrac . Anyone knows what this possibly could be. Cleared code and cars runs fine. MSD 8.5mm wires and NGK Laser Iridium plugs installed. Would a cylinder 6 misfire trigger the stabilitrac mode or is this possibly tune related?
Old 12-23-2014, 07:32 PM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Were those plugs and wires replaced before or after the code? Test/check the #6 plug, wire, coil, and compression.
Everytime someone posts about a misfire they also complain of the stabilitrac light coming on so I'm sure it's related.
TommyTheCat is offline   Reply With Quote
Old 12-26-2014, 01:33 AM   #3
L99CAMA2011
after the code
Old 12-26-2014, 01:35 AM   #4
L99CAMA2011
Compression
Old 01-03-2015, 11:51 PM   #5
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
did this start after the parts or before? and yes it will turn your stability light on.
firestone_ss is offline   Reply With Quote
Old 01-07-2015, 07:21 PM   #6
L99CAMA2011
after
Old 01-08-2015, 02:37 PM   #7
moE_09
Drives: 2014 v6
I'm having the same issues. Goes from p0306 to p0300, I'm starting to get Te feeling it has sometbing to do with the cold temps bc it happned last winter. Was fine allll summer and now it's happening again
moE_09 is offline   Reply With Quote
Old 01-08-2015, 03:52 PM   #8
TommyTheCat
SHKE BKE
Drives: 2013 Camaro
Most likely an ignition coil, a 306 is for cyl 6 which can cause both codes
Old 01-11-2015, 09:41 PM   #9
L99CAMA2011
Knocking sound now like spun rod bearing.
Old 12-07-2018, 07:23 PM   #10
carjockey71@gmail.com
Drives: 2012 Chevrolet Camaro SS Convt
What was the verdict on your car - I’m going through exactly the same things . .
carjockey71@gmail.com is offline   Reply With Quote
Old 12-08-2018, 08:54 PM   #11
Rene59386@gmail.com
Drives: Camaro 2012 v6 nanual transmission
Did you got it fix
Rene59386@gmail.com is offline   Reply With Quote
Old 12-12-2018, 09:17 PM   #12
JrodCamaro
JrodCamaro's Avatar
Drives: 2010 Camaro 2SS RS
In for diagnosis. Throwing sporadic p0300 recently since it got colder. Changed plugs last night, threw code again today. About to pick up wires and hope for an easy fix. Almost wish I was getting a p0171 or p0174 so I knew a bank was running lean ��.
2010 Camaro 2SS/RS M6. Vararam Street Spec tune intake. Speed Engineering 1-7/8 LTH. Powerbond 25% UDP. Custom camshaft from Powell. .660" dual springs from BTR. Trunnion upgrades. Chromoly pushrods.
Tuned by DynoSteve at RDPStore.
JrodCamaro is offline   Reply With Quote
Old 12-12-2018, 09:55 PM   #13
Overflow
Space Shuttle Aficionado
Overflow's Avatar
Drives: 2016 Camaro 2SS
Originally Posted by Rene59386@gmail.com View Post
Did you got it fix
If the CEL is flashing and you're getting a "Service Stabilitrak" message on your DIC, your car is misfiring. You'll have to get a code reader to see exactly which cylinder is misfiring. Can be plugs, wires or ignition coils. Could be something as simple as something came unplugged, or something more extensive.
