Old 02-16-2021, 02:32 PM   #1
Gr33kninja12
V6 Glory
Gr33kninja12's Avatar
Drives: 2013 Camaro V6 M/T
UOA 3.6L V6 LFX 2013 RP HPS
Hey guys just wanted to post my UOA from my camaro this oil was 6 months old at the time changed in August of 2020 to Jan of 21 barely any cold starts on this oil maybe a handful 4-5. around 25-30 Degrees imperial units.
Very healthy driving i would say 60% highway 40% mild suburb stop and go. although im from chicago im more on the west side. 20-30 min Drives
I find it interesting that the TBN was 3.0 and the advisor had said to stretch this oil out, considering i believe ive seen a VOA of this oil at around 11 TBN however that was back when the PPM calcium was way higher. I believe it was lowered due to Calcium being related to LSPI,
Any thoughts on that?
any comments on that or any comments related UOA's would be appreciated Thanks.
Also running a Trifecta tune.
Specs are 3.6L V6 LFX 2013 CAMARO MANUAL TRANS 90-93 octane only
OIL USED; ROYAL PURPLE HPS PURCHASED IN JULY 2020
File Type: pdf Blackstone Labs Oil Analysis Camaro.pdf (96.4 KB, 61 views)
Gr33kninja12 is offline   Reply With Quote
