Old 04-25-2021, 04:00 PM   #1
GAFreddy
Drives: 2010 2SS & 2013 ZL1 Vert
Flexible Oil Dip Stick Tube?
Hello. Hope this is the correct section. I was wondering if anyone has heard or has a flexible dipstick tube for the 5th gen SS.
I did headers on it, and forgot to out the stick in first, before bolting that side on.
Long story short, I mangled the OE tube and do not want to try it again. I'd rather chew on glass and may just the car ablaze if I have to try that again.
Thanks in advance.
GAFreddy is offline   Reply With Quote
Old 04-30-2021, 10:09 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I think you need to take it to a shop or get out your matches.
The dipstick is easier to get in with two people, but it can be done with one. It's easier if you remove the starter and the dipstick should be out when you go to put it in.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 04-30-2021, 01:40 PM   #3
swampcritter
Drives: 2014 Camaro LS / 13 zl1
Lockar makes a flexible dipstick tube
swampcritter is offline   Reply With Quote
Old 05-04-2021, 08:10 AM   #4
GAFreddy
Yea, I'll try that. I got a buddy that works at a shop.
Yea? I wonder if they fit the LS3?
Thanks fellas.
Old 05-06-2021, 07:37 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Look through here to find what you might need.
https://www.bing.com/search?q=ls3+fl...a8100a7f33b79e
