05-01-2021, 06:13 AM | #1 |
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99 Join Date: Feb 2021
How Much Diff Fluid ?
I purchased this car a few months ago and am slowly changing all the regular maintenance items . I am ready to do the diff. fluid , but am confused as to what the OM says . Is the capacity 1 quart total or 1 quart plus the 4 oz. of slip additive ? Thanks for the help !!!
05-01-2021, 08:03 AM | #2 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Yup, that's right. I always get 2 qts because It (for me) always seems to take a bit more.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-01-2021, 06:02 PM | #3 |
05-01-2021, 08:13 PM | #4 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Pour in the slip modifier, then the gear oil until it starts pouring out. Filled.
More to come. |
05-02-2021, 06:13 AM | #5 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Get yourself a good pump to pump the fluid in. They are like $10 in Amazon and I feel like it’s almost impossible without it. I changed mine twice within 10k miles and each time 1 at did the job I use the acdelco with modifier already in it.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
05-03-2021, 05:18 AM | #6 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
When I did mine it also only took one bottle until it started leaking out the hole. And I had to use a pump as well.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
05-08-2021, 05:06 PM | #7 |
Did mine yesterday . I did get a pump from Amazon as recommended . I put about a third of the fluid in , then opened and added the additive to the bottle and finished filling . Started running out just as bottle was empty .
05-09-2021, 01:24 AM | #8 |
Banned
Drives: 2010 LS Join Date: Feb 2021
Car 100% level.
Additive goes in FIRST. Then pump fluid in till it starts to back out the fill. Done. |
06-05-2021, 10:42 AM | #9 |
376 cubic inches of fun
Put the additive in first, then pump in the oil until it's put to the lip of the drain hole.
And yes, you need the additive even though the Delco oil is for LSD. |
06-19-2021, 09:16 AM | #10 |
Drives: 2011 camaro ss Join Date: Sep 2013
I just put a new rear differential in mine about a month ago. I used the ac delco additive and quart of oil. I put the additive in first then the other oil. I didn't buy a pump. I bought some clear tubing jammed in on the cone shaped top and squeezed it in the fill hole until it started coming out. It used it all.
2011 ls3 ss/rs, Kooks long tube headers, gutted high flow cats, 231/239. 624" lifted squared 115+3 lsa comp cam, ecs supercharger, Alky methanol kit, DSS 1000hp axles, BMR toe rods, BMR trailering arms, Fore innovations dual fuel pump. Flex fuel sensor and 360 custom tunes, hp tuners NGAUGE. 752 hp with 93 octane and 825 hp with E85.
