Old 07-31-2010, 03:54 PM   #1
GrinderSS
Drives: IOM 2SS/RS
Question about E-Force Tune
Guys, I'm in the process of installing my E-Force but I'm a bit concerned about the tune Edelbrock supplies with the kit. My car already has a custom tune, which adjusts the speedometer for the 4.10 gears, disables the skip shift, and of course has custom fuel trim levels.
My question is, if I install the Edelbrock tune will it simply make changes to the air/fuel mixture and leave all my other tune settings as they were? I would expect so, but I want to be sure.
GrinderSS is offline   Reply With Quote
Old 08-01-2010, 10:22 AM   #2
Bellringer
Bellringer's Avatar
Drives: my wife nuts.....
Good Question!
I was wondering the same thing on this.
44030 is all mine!
GM
Bellringer is offline   Reply With Quote
Old 08-01-2010, 11:02 AM   #3
GrinderSS
Drives: IOM 2SS/RS
Originally Posted by Bellringer View Post
Good Question!
I've posted the same question on the Edelbrock forum, if they answer any time soon I'll post their response here.
Old 08-01-2010, 11:26 AM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
it comes with a handheld tuner (SCT I think)...I would think you'd be able to adjust those things w/ the tuner.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 08-01-2010, 11:51 AM   #5
SupremacyCustoms
SupremacyCustoms's Avatar
Drives: black 2010 2ss/rs camaro
You Should be able to adjust with the tuner but just remember the tune they send you is for a stock motor with just their suprecharger. To get the best results bring it to you tuner and get it dyno tune see your numbers and know everything is running right.
SupremacyCustoms is offline   Reply With Quote
Old 08-01-2010, 04:21 PM   #6
GrinderSS
Drives: IOM 2SS/RS
Thanks...and yes, that's what I was thinking.
Old 08-01-2010, 07:22 PM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
The Tune that comes with the supercharger is for the supercharger system installed on a stock car.
If you car has headers or an aftermarket air box then you need a custom tune.
The SCT that comes with the Edelbrock does NOT have any user adjustable options, it is a set it and forget it tune file.
The Edelbrock tune will overwrite your current custom tune changes.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-01-2010, 08:58 PM   #8
GrinderSS
Drives: IOM 2SS/RS
Ted.
Ted, are you sure it will overwrite all the ECM settings? It seems to me they would load your current tune into the SCT, adjust the air/fuel parameters and flash it back into the ECM. Thus, leaving the speedo, skip shift, rev limit, etc setting unchanged.
Old 08-01-2010, 09:21 PM   #9
SupremacyCustoms
Yes it will change your settings you have now.
Old 08-02-2010, 08:06 AM   #10
JANNETTYRACING
It depends on how the changes are applied and to what.
Here are a couple possibilities.
1) It takes the file out of the car and applies a Value file that only makes certain changes.
2) It looks at the calibration number and works from a database and applies the full Edelbrock calibration.
3) It Takes the file out of the car and applies the full Edelbrock Calibration.
Since the Tuner is Universal for all 2010 Camaros, I would expect it to pull the calibration from the car and apply the Edelbrock Value File.
In this case it would leave things like Rev limit, Speed Limit, and Gear Changes alone since Edelbrock does not adjust these settings.
But Mass air calibration, Commanded A/F ratio, Power enrichment, Timing, injector values, torque management, Mass air tests, Map tests, certain codes, all will be changed.
Ted.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3652 08-17-2023 02:50 PM
Its JUST a V6 ROD1 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 26 06-29-2010 02:57 PM
SCT TUNE after Maggie install racer778 Tuning / Diagnostics -- engine and transmission 3 03-23-2010 01:22 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
