11-19-2012, 03:48 PM | #1 |
Drives: 2013 Camaro 2SS Join Date: Aug 2012
Kooks LT Headers Installed - Now Squeaky Noise
So after I got my Kooks LT headers installed I started hearing a squeaking noise. I asked the shop that installed, they said you hear more of the valve train now. I wasn't sure how that equals squeaking, but anyways I took it to the dealer today to get a 2nd opinion, thinking it was a belt, or something. My dealership has a mechanic who is into racing, and without letting them know what the other shop said, they told me its because of the headers and hearing the valve train now! I was shocked. Does anyone else have this? Also is there a fix?
11-19-2012, 03:51 PM | #2 |
Drives: 2012 2SS/RS LS3 Join Date: May 2012
I have Kooks LTs and hear the valve train a little more than stock. Doesn't bother me though.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA Kooks 1-7/8" LTs w/ Cats Roto-Fab, Bo White TB, Borla Touring Catback 3.91 1LE Gears, MGW Tuned by Pat G |
11-19-2012, 06:54 PM | #3 |
Drives: 2010 Camaro SS, 2018 Colorado Join Date: Nov 2009
Google "sewing machine" sounds, unless you know the sound. Is that what you hear? Normal.
11-19-2012, 07:05 PM | #4 |
9691 & 97586
Drives: 2010 SS, 1999 SS, 1993 Z28 Join Date: Mar 2009
I just swapped headers and had that same sound... it was a header gasket leak... sound like a popping squeak sound.... have you check ur header bolts since the install? Recheck those and if it doesn't stop, you may wanna buy new gaskets.. go OEM.. i think they're around 12 or 15 each.
Sent from my DROID BIONIC using Tapatalk 2
11-19-2012, 07:08 PM | #5 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
If it is the valvetrain, all headers will sound this way. They are made of thinner metal than the cast manifolds so you'll hear more of the valvetrain noise. It's always been that way. A tune will quiet it down considerably, if you don't have one. Cats will quiet it down even more, but you'll never get rid of it completely.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
11-19-2012, 07:23 PM | #6 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
It's all in your head taco!
11-19-2012, 09:06 PM | #7 |
Car did get tuned. Its definitely a squeak, not sure how hearing valve train sounds like squeaking though
11-19-2012, 10:04 PM | #8 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
Valvetrain noise sounds like ticking. If it is squeeking...does it happen constantly, or over bumps? If it is over bumps, a connection could be loose, or a hanger needs to be sprayed with WD40. Also check the tunnel brace and do forth.
If it is a real complaint, not related to the normal sounds a header system makes, a good performance shop should be able to sniff it out fast. |
11-19-2012, 10:48 PM | #9 |
car can be in park and u really hear it when the engine is decellerating.
11-19-2012, 10:56 PM | #10 |
I would have an exhaust shop look it over. If the place used the gaskets that came with the headers, that could be the issue. It's been posted here a lot, and most shops know to reuse, or get new OEM gaskets. The gaskets included with most aftermarket headers are cheap, and don't work well. However a leak at the gasket would also be kind of obvious as there would be some kind of exhaust streaking around the flange.
Before I did that though, I would check all the slipfits, and the ball and socket connection and make sure stuff is tight. |
11-20-2012, 05:08 PM | #11 |
V8 Lounge member #2
Straightline won't use the kooks gaskets, I know that for a fact.
If its a squeak it had nothing to do with a header install. Check your belts and pulleys.
11-21-2012, 07:20 PM | #12 |
Drives: 2010 2ss camaro Join Date: Jan 2010
Ihad the same thing happen to me on install and it was an exhaust leak at the headers,I would really hear it on deceleration and would go away under 1200 rpm.Just replace your hearder gaskets.
11-21-2012, 08:07 PM | #13 |
V8 Lounge member #2
It was a brand new car, those GM exhaust gaskets are pretty damn good, maybe you need to give it one more pass if it is leaking, they do back up a lil SOMETIMES after a few heat cycles and that is NORMAL just part of the modding maintenance.
