01-15-2012, 12:04 PM | #1 |
Throttle Body clean DIY?
Has anyone done this maintenance themselves, the dealer has been recommending this each time i bring my Camaro in for maintenance.
01-15-2012, 12:49 PM | #2 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Easy to do, just remove the 4 bolts and unplug TB, remove it and use 1 can of carb cleaner. DO NOT spray in the electronics part though.
Best is to install a proper oil separating catchcan and breather kit and you should never need this serivce again as you eliminate the oil ingestion causing this and more serious issues....but then again, your dealer wont make all theat monet with the extra services to charge for. |
01-15-2012, 12:55 PM | #3 |
So-Cal Race team!!
Drives: Tahoe LTZ,2010 2SS/M6 Camaro Join Date: Apr 2009
I did this the other day real easy...and I do have a catch can there was some muck on it.My car was running sluggish andstarted to miss.But not check light????...Finnaly after of 2 weeks of my car running like crap at the Autocross event the light came on !!!! My buddy had a STS tuner and check the code...# 4 missfire??????......Well long story short after 8k miles my new HP Spark plug wires were shit ..burnt falling apart ..$49 autozone deal back to good as new!!!! car runs great now.....now that I think about it my was running ruff and missing once in awhile for about over a month........But cleaning the TB is easy ...that was the first thing I did..
WE RACE DEEP!!
BBK Intake, Flowmaster AT cat back Barton shifter,Painted stripes,,Heritage grill,LED DRLs, Smokin Tires!! |
01-15-2012, 02:02 PM | #4 |
DDunerider...are you running the RX breather kit as well? If not theen oil does ingest before the TB and that is an issue. Also, only a few catchcans really are effective in stopping the oil....many let nearly as much through as they catch.
01-15-2012, 03:55 PM | #5 |
Drives: 2010 SS/RS 2009 CG Z06 Join Date: Nov 2009
One should figure out WHY there is oil in the TB in the first place. There should be NONE.
01-15-2012, 04:28 PM | #6 |
Pretty simple....at WOT there is a good deal of reversion through the stock fresh air tube ingested upstream of the TB so that will usually show up on the blade & throat of the TB. The majority is ingested through the OEM PCV into the intake manifold but you want NO oil ever ingested into the intake air charge NA or FI.
We delete the OEM line and use a flow controlled checkvalved breather that only allows the amount of fresh air the ECU can deal with properly not metered by the MAF. We use a differnt flow for V6 & V8. Using a plain breather with no flow control and your fuel trims will be all over the place as the ECU trys to compensate for the mixed data the MAF, MAP, and upstream O2's are feeding it. The proper functioning oil separating can inline in the PCV routing will eliminate oil into the intake manifold but the problem is there are so many marginally functional cans on the market that allow almost as much oil through as they catch and that still creates the problems related to oil ingestion into the intake air charge. |
01-15-2012, 05:39 PM | #7 |
Drives: 2010 ss. 1990 RS the faster one. Join Date: Jan 2011
Removing the TB is not an absolute necessity. It's a 4in. Opening, you will be able to get 99% of the carbon cleaned out. You can remove it if you want, just keep in mind that the TAC system is VERY sensitive and any damage to the connector terminals will result in The vehicle defaulting to limp mode. I usually put some throttle body cleaner on a rag, hold the TB wide open and wipe it clean. Either way you choose to do it is better than not doing it. These engines control idle differently than in the past and coking in the TB will have noticeable affects on driveability.
01-15-2012, 05:50 PM | #8 | |
01-15-2012, 07:52 PM | #9 |
THERAPY
Who sells a good catch can, and is it easy to install?
01-16-2012, 05:34 PM | #10 |
So-Cal Race team!!
I have a Rx Catch can but no breather..there was a little gunk on the TB to clean,,
WE RACE DEEP!!
01-16-2012, 05:43 PM | #11 | |
THERAPY
01-16-2012, 05:48 PM | #12 | |
On the cleaner, no need to use a whole can.....just enough to wipe it clean. |
01-17-2012, 10:00 AM | #13 |
THERAPY
01-17-2012, 10:17 AM | #14 |
Totally into it
Drives: '67 427vette/'11 Pacecar/'02 BMW ci Join Date: Feb 2011
____________________________________THERE MUST BE A SUPPORT GROUP FOR THIS ADDICTION. AM I IN THE RIGHT PLACE?
Similar Threads | ||||
Cold Air intake, throttle body, headers, lots of questions. | shadowghost21 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 6 | 10-09-2011 03:59 PM |
VMax CNC Throttle Body Dyno Test Data | Mike Norris | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 01-15-2011 08:28 AM |
Throttle Body Porting | lxporting | V8 Bolt-Ons & Tunes | 133 | 05-10-2010 12:23 AM |
Ported throttle body sale | matt d. | V8 Bolt-Ons & Tunes | 3 | 11-24-2009 12:11 AM |
