07-10-2010, 12:17 PM | #1 |
Drives: 2010 IBM Camaro SS Join Date: Jun 2007
Exhaust rattle near the resonator area?
I recently installed the Solo High Flow cats and have a new rattle/vibration.
This rattle happens when the car is first started as the RPMs fall back down to idle and also if I rev the engine. The rattle happens on the down-swing of RPM not the way up. I believe I have isolated it to where the resonator (L99) sits on/near the black cross brace. So my question is this; What is a good way to deal with this? Is there a way to add new hangers to the front portion of the exhaust to keep it off the brace? (or a pad of some sort that would be able to go there?)
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
07-10-2010, 12:23 PM | #2 |
Dont H8 Me Cuz U Aint Me
Drives: 2016 SS Sedan, 2017 Explorer Sport Join Date: Feb 2010
Alot of guys have had to use washers and lower the brace 1/2inch or so.
I would try unbolting the coupler between your HF cats and your catback and press up on the exhaust system and while its pressed up you must re-tighten while something is holding up the exhaust side. It may help.
07-10-2010, 07:58 PM | #3 |
So far so good.. I loosened the clamps and used a Jack to push them up as high as they could go, then re-tightened. Also added a couple washers to each bolt on the brace. Initial tests suggest the rattle is gone.
07-11-2010, 06:46 PM | #4 |
Well, that first issue is gone but the exhaust still hits the brace when I an driving (from bumps in the road etc). I cant move it any further so I wonder if I can install some sort of pad, or maybe some clamps to keep the exhaust pipe from hitting that.
Similar Threads | ||||
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 05:56 PM |
New low profile electric exhaust cutouts for your Camaro @ PFYC.com | Redshift | V8 Bolt-Ons & Tunes | 8 | 08-14-2014 04:19 PM |
November Month Special on 2010 Camaro Corsa Exhaust | GmPartsDirect.com | V8 Bolt-Ons & Tunes | 0 | 11-01-2009 11:46 AM |
L99 exhaust rattle any help | 2003chevy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 07-24-2009 07:21 AM |
