03-06-2014, 04:06 PM | #1 |
1LE rpm's
hi 1LE owners..i would like to know,
how much the ls3 is running--rpm- in 6th gear at 60mph and 75mph. since you have 3.91 gears. Thanks! |
03-06-2014, 04:21 PM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Generally 1200ish for 60mph and about 1800ish for 75mph. I think... I know for a fact that 80mph is @ 2000rpm.
Sent from my DROID RAZR HD using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
03-06-2014, 05:00 PM | #3 |
thanks! that's not so bad. thought it was higher than that. like mid-2k's.
03-06-2014, 05:28 PM | #4 |
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV Join Date: Feb 2013
Due to the gearing in the 1LE transmission, the rpm's are actually a tick lower cruising in 6th gear than a regular SS.
03-06-2014, 05:34 PM | #5 |
still a reg ss has what 3.42 diff?? always speaking with a manual. don't know if ss has a different gearing with auto but don't care. long live the manual!!!
03-06-2014, 05:43 PM | #6 |
Drives: '14 1LE Join Date: Nov 2013
SS has the M10 transmission with 3.45 gears, and the SS/1LE has the MM6 transmission with 3.91 gears. Take a look at these threads for some background info
http://www.camaro5.com/forums/showthread.php?t=248150 http://www.camaro5.com/forums/showthread.php?t=329619 |
03-06-2014, 07:03 PM | #7 | |
03-06-2014, 07:05 PM | #8 |
03-06-2014, 08:09 PM | #9 |
much appreciated
Thanks again guys for all your input |
03-07-2014, 02:57 PM | #10 | |
The Beast
Drives: 13 2SS/1LE/RS/NPP/NAV/SUNROOF Join Date: Apr 2013
Wouldnt a stock ss vs 1le over 1/2 mile the 1le would have the advantage...I know the 1le loses a little mph topped out but, you would get up quicker in 4,5,6, right?
N.F CAM, P&P HEADS, SLP UDP, C.A.I., TRI Y'S, BMR 1" SPRINGS & SWAYS, PFADT TIE RODS & TRAILING ARMS, TUNED BY MATT@FSP 490HP/428TQ
03-07-2014, 03:50 PM | #11 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
The whole purpose of the tranny rear end set-up in the 1LE is to have closer rations (not as big a difference between the gear ratios) for gears 2 - 4. 1, 5, and 6 have very similar final drive ratios between the two cars. Closer 2 - 4 equals better lap times on the road course. If a larger rear gear is mounted behind the same transmission, it will lower the cars top end, and reduce the time it takes to get it there (Assuming the car can hook-up at the start). All that changes when the gears in the transmission change as well. Putting a 3.91 in a standard SS with no transmission change will make it quicker than it was (Again assuming it will hook up), but it will not improve its ability to be in the right gear on the road course. I hope that helped.
03-07-2014, 03:55 PM | #12 |
Dean Voss
1LE gears and Dyno.
I installed the 1LE gears in my 2010 Camaro, DSS One piece driveshaft. JRE belt tensioner, ZR1 plugs, and GMS-28-1811HT plug wires. My Camaro was on the dyno before I added those parts on the car. It was Dynoed at 558 hp. I also installed a Roto-fab CAI. I just had the car on the Mustang Dyno and It did 603 hp. If I ran my car on a Dynojet the rwhp would be 12% higher at 675.46 HP. Those that disagree with me can reply or post !!!
03-07-2014, 04:30 PM | #13 | |
03-07-2014, 04:37 PM | #14 | |
