#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
BeckyD @ James Martin Chevy
Old 06-03-2019, 03:57 PM   #1
David@Vengeance
Drives: 2017 Camaro SS 1LE
NEW Vengeance Racing LT1 Rod and Piston Combo!
Vengeance Racing has teamed up with a group of our preferred high-performance manufacturers to put together the ultimate solution of forged connecting rods and pistons for the Gen V LT1 engine! This rod/piston combination was tested thoroughly in our " Horsepower Wars" 2019 Camaro SS that makes just over 950rwhp via a Procharger D1X and other Vengeance Racing performance parts. This combination was brutally tested in extreme temperatures and high/sustained RPM at this power level. We rate this combination to 1,200+ HP and requires no balancing or machine work, making it a much simpler solution to handle power in your LT1.
Piston Specs:
- 2618 Forging
- .927 Heavy Duty .200 Wall Wrist Pins
- Drops Compression to 10.5:1 (60cc Chamber/ .051 Head Gasket)
Rings Specs:
- Mahle
- .043/.043/2.0mm
Rod Specs:
- Molnar “LS Power Adder” Series Connecting Rods
- 6.125" Length
- 7/16” ARP 2000 Rod Bolts
Bearing Specs:
- Clevite 663HN
**Installation requires verifying proper bearing clearance/measuring proper rod bolt stretch & filing rings for proper ring gap**
Pricing at $2,099.99 “Dealer Inquiries Welcome”
David@Vengeance is offline   Reply With Quote
Old 06-10-2019, 10:19 AM   #2
David@Vengeance
To the top^^^
