02-01-2016, 08:47 PM | #1 |
Drives: 2010 2ss RS. White (RIP) 2012 LS3 Join Date: Sep 2011
Footwell lighting I know it's been done to death. But.
I've literally read every single thread I coukd find on it today. And read mention of this, but nothing to definitive.
Has anyone hooked up their lights to the cigarette lighter. Meaning, tapping into the hot wire of the cigarette outlet. That way, the footwell lighting only comes on when the car is running and goes out automatically when the car shuts off. Then no messing with switches or anything. This is really the route I wanna go with it. Any advice on which wire to tap into. I've also heard mention of fuse 17 in the drive side fuse box. And that it switched power as well. So I coukd achieve the same exact results as tapping into the cigarette lighter wire. Any thoughts on this guy's? Also, in case anyone was wondering, I footwell lighting hook up now with a switch. and it's on off whether the car is running or not. And right after hooking it all up I went away for a week and left the footwell lighting on. And the car didn't die! |
02-01-2016, 11:25 PM | #2 |
Drives: 2015 1lt Join Date: Oct 2015
Just tap into the yellow wire coming from the traction control switch. The lights will turn on when it is dark out and go off when it's not automatically. If you want them to come on when it is not dark out you can turn them on by turning the parking lights or head lights on. And you can also control the brightness with the dimmer switch that controls all of the other dash and switch lighting.
02-01-2016, 11:35 PM | #3 |
I did something else but for the life of me I cant remember where I made the connection. They come on when the door is opened and off when its closed. They are connected to the interior lighting circuit so can be manually turned on with the interior light dimmer switch. Hmmmm. Where is that wire?
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
02-01-2016, 11:39 PM | #4 | |
02-02-2016, 07:27 AM | #5 |
Drives: 2011 2SS/RS Join Date: Feb 2014
I did exactly what you're referencing.
I bought THIS kit off amazon, and it comes with fuse taps/fuses. I just tapped into the fuse for the cig lighter (probably 17, can't recall off the top of my head) and it functions as you're wanting it to. The LED controller is tucked away in that nook, wires are all ran behind/under the dash, and it comes on with the vehicle either 'on' or 'accessory' When I turn it off, lights go off. It also has it's own remote, so you can change colors/dim/brigten/turn off with the remote while the vehicle is on if you're heading down the road and don't want them on. A little piece of velcro on the back of the remote, and the opposing piece on the map pocket in the drivers side door makes easy storage/access for the remote, and it's not sliding around inside the center console. Hit me up if you have any questions, or want pics... It's a REALLY simple install. Literally took me more time to figure out light placement and wire routing than it did to actually do the work. Total time was probably an hr and a half? Maybe 2 hrs including 2 beers? You could also wire this directly into the cig lighter wiring, but it's a much cleaner/easier install to use the supplied fuse tap. |
02-02-2016, 07:33 AM | #6 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
I connected mine to the gray wire. Only come on when the door is opened or I can turn them
on while driving with the dome light switch. Best of both worlds imo. |
02-02-2016, 08:12 AM | #7 | |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
02-02-2016, 09:09 AM | #8 | |
02-02-2016, 09:17 AM | #9 | |
02-02-2016, 09:35 AM | #10 |
Drives: 2014 Chevy Camaro SS Join Date: Oct 2014
I tapped in to the Dome Light. I did that because I only wanted lighting when the doors were open. Works well and the kit I got off of Amazon was only like 42 bucks.
Number of people killed by wolves last year... Zero
Number of people killed retrieving change from a Vending Machine.. Six |
02-02-2016, 09:50 AM | #11 |
02-02-2016, 12:24 PM | #12 |
02-02-2016, 01:35 PM | #13 |
02-02-2016, 01:35 PM | #14 | |
Drives: 2014 2SS/RS Join Date: Dec 2014
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
