06-03-2012, 11:38 AM | #1 |
Drives: 2012 Ashen ZL1 Join Date: Nov 2011
Engine hesitation
Guys - have you experienced any engine hesitation while driving? Every time I drive between 30 - 40 miles or when RPM's are between 1,000 to 2,000 - I'll get engine hesitation.
Thanks in advance for your help. P.S. I have already changed engine oil,spark plugs, cleaned MAF and added fuel additive Last edited by Frankzl1; 06-03-2012 at 11:50 AM. |
06-03-2012, 11:59 AM | #2 |
ZL1 #140
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1 Join Date: Mar 2008
I'm surprised your ZL1 would already need new spark plugs and a fuel additive. Here's a thread I started on a similar issue with mine but little different and hard to reproduce.
http://www.camaro5.com/forums/showthread.php?t=228001 |
06-03-2012, 12:08 PM | #3 |
I changed the spark plugs just rule things out and I am not getting any codes
06-03-2012, 12:15 PM | #4 |
Drives: 2010 Duramax; 2012 CTS-V Coupe Join Date: Apr 2012
What's the mileage and do you have a manual or auto? Give it a battery nap for 10 minutes so it dumps all the tables and starts fresh on the cals and see if that fixes it.
06-03-2012, 12:29 PM | #5 | |
Thank you guys!!! |
06-03-2012, 12:41 PM | #6 |
A few seconds isn't enough to dump all the power stored in the capacitors. Pull it for about 10 mins then go for a spin. Drive it for at least 10 miles going through normal city driving and a short run on the freeway so it starts relearning. If you got some bad gas it could cause this problem as well.
06-03-2012, 01:31 PM | #7 |
Drives: 2013 ZL1 Join Date: Oct 2011
there is almost 0% chance the plugs or anthing to do with lubrications. on something this new you should never change the plugs just inspect them. once you learn how to read plugs you would imediatly know if there was an issue or not just by looking at them.
bad fuel usually just caused it to run bad period. my .02 is take it to the dealership if it is repeatable. why waste your time and money with such a new car? on a car this new it could be an issue with the programing. if it is partial throttle it could be any number of feedback systems for the injection system. a bad knock sensor, TPS senor, etc could cause the car to behave eratically. does it go away if you just floor and and go into open loop and just rely on the spark fuel tables in the tune?
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
06-03-2012, 03:06 PM | #8 |
It might be bad gas, because it happened after I filled up a 1 week ago, but I have refilled since then and that's why I put the additive-it didn't do anything.
I am disconnecting the battery and I'll let you guys know |
06-03-2012, 07:21 PM | #9 |
I disconnected the battery, didn't take The issue away,but it got much better-I am taking to mechanic tomorrow and lets see what happens.
Thanks again!! |
06-03-2012, 07:32 PM | #10 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
Funny this post was mentioned.....as today I took the car for an extended drive. Weather conditions were good, mid 70's with not too high relative humidity, some humidity, but overall pretty decent air. On one occassion, while shifting into second and then stepping into the throttle at a progressive rate...the motor felt like it had a vacuum secondary carburetor on it, there was a slight pause and then the motor pulled out of it. That's the only way I can describe it. A slight pause, then the power came on in a gradual fashion. One time only....low speed 30-40 MPH...
06-03-2012, 07:37 PM | #11 |
DBLCHBY III
Drives: 15 1LE Join Date: Jun 2011
http://www.camaro5.com/forums/showthread.php?t=228259 mine has gotten so bad from about 30mph to 45mph ind 2nd gear its going to my dealer tommorow
06-03-2012, 07:46 PM | #12 |
Drives: 2013 WRX Sedan Join Date: Aug 2009
I know first run models have their issues, but geez! The problems keep stacking up.
06-03-2012, 07:48 PM | #13 | |
06-03-2012, 07:50 PM | #14 |
DBLCHBY III
when it goes into 2nd it bounces all over the place
