05-26-2013, 05:20 AM | #1 |
When 3m tape doesn't work ...what to use?
Ok, I tried everytype of 3m tape. From the cheap to the heavy duty and nothing sticks to the area of the engine bay I am attempting to mount an scanner strip. Is there any type of silicone that is heat resistent? Or do you guys have any other ideas? Thanks and Happy Memorial Day!
05-26-2013, 06:01 AM | #2 |
Drives: . Join Date: Nov 2012
Have you tried adhesive promotor? Make sure the surface is absolutely clean too.
05-26-2013, 09:20 AM | #3 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
the tape will work but the surface has to be clean, clean, clean - try scrubbing both surfaces with rubbing alcohol and roughing it up a bit with 1500 grit wet dry paper, it'll stick...
I like the red #m exterior tape - I've never had it fail anywhere I ve used it: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 |
05-26-2013, 07:35 PM | #4 |
Thanks guys for the feedback. I am trying to adhere it to the plastic lip type cover that extends a little over the top of the engine bay. On my way to work this morning....I thought about scuffing it up as well, because it is extremely smooth. Appreciate the feedback!
05-26-2013, 07:38 PM | #5 |
Da WHALE
Drives: 2014 Stingray, 2015 Panamera 4 Join Date: Dec 2011
5 minute epoxy...
Project MantaRay...Underway
