Old 08-12-2014, 09:14 PM   #1
rrrocketman
youtube.com/c/ChrisCamaro
Drives: 2013 Camaro SS w/ NPP and Hi Wing
CAI Fresh Air Locations
I have seen many CAI setups that put the filter near the fender with some sort of a box or shield protecting it from engine heat but I've never been too fond of that setup. Ideally I'd like to get around the rad and access some of the air coming through the grille but I don't know how this can be practically done since inspection doesn't immediately reveal a suitable path for the tubing. Has anyone attempted this and if so, what challenges did you face and how did you end up installing it? If possible I'd like to steer clear of cutting holes in hoods or body sheet metal as well. Thanks.
rrrocketman is offline   Reply With Quote
Old 08-13-2014, 06:37 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
There isn't an easy route around the radiator for an intake tube but what you are describing is exactly what the Apex scoop does. It funnels are from the lower front grill into the air box. It can be used with any of the systems that have the air box in the front drivers side corner of the engine bay and have an open bottom. The only other option would be something like an Injen intake but that does not perform as well.
Difference between scoop/washer bottle's?
Old 08-13-2014, 08:58 AM   #3
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Vararam might be another option you may be interested in.
11TexaSS is offline   Reply With Quote
Old 08-13-2014, 10:07 AM   #4
Apex Motorsports
There is not a Vararam application for the 2013 model.
Old 08-13-2014, 10:15 AM   #5
62nalide
62nalide's Avatar
Drives: 2013 SS
New Era has a OTR for the 13s, heck I love mine
62nalide is offline   Reply With Quote
Old 08-13-2014, 10:31 AM   #6
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Don't forget that the air coming into the grille at the front of the vehicle is the same air that is flowing a foot lower under the car and outside the car through the inner fender well. The important thing is that you are pulling in the cooler ambient air from outside of the vehicle, rather than the hot air in the engine bay. Hence why our CAI pulls air from the inner fender well, which is also where the stock system pulls its air from. Sometimes we re-invent the wheel to no added benefit, I'm just trying to save you some headache and time. I hope that information is helpful, let us know if you have any questions!
Sales @ CAI Inc is offline   Reply With Quote
Old 08-13-2014, 11:20 AM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
The Short-ram style intake systems are the better option in my opinion. The benefit of this style is better throttle response due to less tubing. As long as you have a properly sealed air box isolating the engine heat away, you're essentially getting the best of both worlds.
I'm sure the scoops help to a degree...but the majority of the gain is simply from removing the windshield washer reservoir out of the path of air ingestion. Roto-Fab has a really clean W/W res relocation kit.
Feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 08-13-2014, 12:20 PM   #8
rrrocketman
All very interesting and useful feedback. Thank you all. In my professional opinion, the loss of head resulting from increased skin friction is offset (and then some) by the charge density from the cooler air. My IAT sensor indicates rapid heat soak of 30+ degrees in a minute or 2 of idling and with compression adding even more heat, I see a tremendous benefit in simply drawing air from the right place, irrespective of any incidental gains in flow... That and using nitrous as an intercooler :P
Old 08-13-2014, 12:37 PM   #9
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
I like my Injen.
its a syn is offline   Reply With Quote
Old 08-13-2014, 12:41 PM   #10
rrrocketman
Where does that go? Where's the filter?
Old 08-13-2014, 12:47 PM   #11
STL20102SS
STL20102SS's Avatar
Drives: SW 2010 2SS/RS
I like my Injen as well!
2010 Summit White 2SS/RS M6: Injen longtube cold air intake, Borla S-Type cat-back exhaust, Tint, White painted rear diffuser, Red powder-coated Brembo calipers, New Era Performance ported throttle body, BMR 1" lowering springs, Hotchkis Chassis Max Strut Tower Brace, Red hash stripes, Vossen Matte Graphite/Machined CV5's
STL20102SS is offline   Reply With Quote
Old 08-13-2014, 12:54 PM   #12
its a syn
B.O.D. 02/16/10
its a syn's Avatar
It is down in front of your plastic inner fender well and grille.
Old 08-13-2014, 12:57 PM   #13
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Nice brace, this is my updated photo!
Old 08-13-2014, 01:01 PM   #14
STL20102SS
STL20102SS's Avatar
Looks good!
