04-16-2012, 07:12 PM | #1 |
Upgraded BMR suspension creaks (Install Issue?)
Last weekend I added outer Trailing Arm Bushings to my suspension build. While doing that I found the source of the creaking sound I have been hearing. So I recorded a video:
The squeaking was there before I did the Trailing Arm outer bushings. Any theories? The rides seems a bit stiffer after all the bushings. Could it be they were not "timed"? (I did not do the install.) Could it be they were not lubed? Also after my test drive it seemed to me the suspension compliance suffered a little. I wonder about binding.... As to the outer Trailing arm bushings I did this: 1. I Loosely tightened the 4 outer through bolts on the jackstands. I needed to also unbolt the Lower Control Arm on both side and raise the trailing arm to pull out the TA bolts. 2. I put the wheels back on and drove the back end up a set of ramps. 3. Since I could not get my prehistoric torque wrench in there I pulled on an 8 inch box end pretty hard. Think I could over shoot 80 lbs? I do hit the gym on a regular basis. 4. Even if i did overshoot a little doesn't the outer link bushing design preclude binding? Loving the handling and the overall neutral feel of the car. And no more wheelhop or step-out with the outer TA bushings. But creaking and worrying about binding? :(
"Democracy Dies in Darkness" Last edited by Fraxum; 07-10-2015 at 08:12 AM. |
04-19-2012, 08:32 AM | #2 |
Drives: 2010 1SS Join Date: Jan 2010
If greased properly, a poly bushing doesn't even need to be timed. The OE rubber bushings need it because the inner sleeve of the bushing is bonded to the rubber so it must actually twist the rubber to rotate. Poly bushings have a free-floating internal sleeve so they can't bind. It sounds like you just need more lube. If you said the noise was there before you installed the outer bushings (at the spindle), it must be the front trailing arm bushings. I would pump more grease into the front bushing. If they were installed without any grease on the outer surfaces it will take a few pumps and some suspension cycling to lube those surfaces. Our bushings have internal flutes that direct grease from the inside to the outer thrust surfaces so it will take a few pumps to get the grease out there plus some cycling to spread it onto the thrust surface. If you still have some noise just lower the trailing arm and re-grease the outer bushing surfaces.
Let us know how it goes! |
04-19-2012, 06:19 PM | #3 | |
BMR Pro Cradle bushings BMR Pro Diff bushngs BMR Adjustable sways BMR Toe rods BMR Trailing Arms So which of these are possible culprits? I can get grease in those culprits without taking things apart? What kind of grease?
"Democracy Dies in Darkness" |
04-19-2012, 06:36 PM | #4 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
Make sure your sway bars are lubed properly, mine creaked a little then I re-lubed them and all better!
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
04-19-2012, 06:46 PM | #5 |
Drives: cars Join Date: May 2011
I'd vote sways too.
04-20-2012, 06:44 AM | #6 | |
04-20-2012, 08:27 AM | #7 | |
04-20-2012, 08:32 AM | #8 | |
If the diff has to come out I will take it back.
04-20-2012, 09:48 AM | #9 |
Drives: Race Car Join Date: Sep 2009
Lube the parts that are simple to get to first. I would start off lubing the trailing arms, toe rods, and sway bars. After you get these lubed up see if the noise is still there or not. If it is move on to the more difficult stuff. I have a feeling that it is more than likely the sway bars will be the culprit. Let us know what you find.
05-16-2012, 09:44 PM | #10 |
After lubing the rear sway bar and giving it some time I still have the squeaky rear. Will I have to drop the differential to get at the bushings? Or should I try to back to my installer. That was a year ago.
Any one else have bushing squeak? I also now have occasional popping sounds from the rear. End links?
05-17-2012, 02:28 PM | #11 | |
05-17-2012, 08:43 PM | #12 | |
First, I gotta get that old Forester out of the garage. Fixing it up to go off to college.
11-12-2012, 02:54 PM | #13 | |
Drives: 2010 Camaro SS2 DeadBLK Join Date: Nov 2010
Did you find the cause of the rear squeaking? I have the following BMR pieces out back: Solid Cradle mounts Poly diff mounts Adjustable Lower Control arms Racing sways spherical toe rods spherical end links spherical rear control arms poly outer control arm bushing inner upper control arm bushing Re-Lubed the outer control arm bush and Lower control arm bushings but squeaking still there. Re-lubing the sways tonight but I'm starting to think its the upper control arms or the cradle mounts didn't seat properly... What cured yours?
11-12-2012, 06:58 PM | #14 | |
Similar Threads | ||||
BMR Suspension Handling Packages Starting At $539 Now Available At APEX Motorsports!! | Apex Motorsports | Suspension / Chassis / Brakes | 144 | 08-10-2012 06:27 PM |
Join Team BMR at LSX Shootout!! | BMR Sales | Suspension / Brakes / Chassis | 5 | 10-11-2011 05:01 PM |
Join Team BMR at LSX Shootout!! | BMR Sales | Dragstrip and Launch Techniques Discussion | 0 | 09-30-2011 11:28 AM |
BMR Suspension Congratulates Ed Timmerman for LS Fest Speed Stop Challenge Victory | BMR Sales | Dragstrip and Launch Techniques Discussion | 6 | 09-29-2011 01:47 PM |
