07-29-2012, 07:23 AM | #1 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
Rear window separating. Anyone have this?
Got my car out yesterday to polish it up real nice. I noticed some waterspots/streaks on the inside the back window. Seemed odd, but after a closer look, the back window is starting to pull away from the trim and there is a small gap between the surrounding trim and edge of the window glass. Was wondering if anyone else has this issue. Mine is a 1400 mile car that is rarely driven, always garaged with the top up. I know this issue will only get worse over time. I guess I am due for a new top now. The rub mark that I have on the passenger side is tolerable, but not a rub mark and a window pulling away.
07-29-2012, 07:51 AM | #2 |
Drives: 2011 2SS Convert; Color RJT Join Date: Sep 2009
Bass Vibrations!!
07-29-2012, 08:20 AM | #3 |
Drives: 2012 45th convertible ss ls3 Join Date: Apr 2012
welcome to the top replacement club... atleast from what ive been reading, it looks like the newest design out by gm looks promising. when you bring it in, demand to have a GM specialist install it, or your begging for future problems.
07-29-2012, 08:54 AM | #4 |
Drives: 2011 (L99) 2SS/RS vert Join Date: Jan 2012
Is it separating on the inside of the glass or outside? I had this happen on the inside and the dealer simply ziplocked it back in.
07-30-2012, 07:12 AM | #5 | |
Drives: Yes Join Date: Nov 2009
As for the glass pulling away from the top, I hope evlar is right - just "press 'n seal" it back into place. Somehow, that sounds too good to be true. |
07-30-2012, 02:33 PM | #6 | |
Drives: GM Vehicles Join Date: Jun 2010
Brandon Chevrolet Customer Service
07-30-2012, 03:22 PM | #7 |
Drives: 2011 Red 2SS RS Convertible Join Date: May 2011
mine is separating at the top inside part of the "headliner", for a lack of a better word. Ive called the dealer twice so far, and they havent called back yet.
My top was replaced in May, Ive been back to the dealer 6 times because of the top, on the other side of town. Ive spent 400 dollars of my own money in gas driving back and forth.(and yes, im keeping track of it). Ive take 2 days off from work to get the car in and out on their schedule, because they outsourced it to a trim shop.
1970 Camaro ,2011 Red Convertible 2SS,2008 Saturn Sky,2012 Jeep Wrangler |
07-30-2012, 05:18 PM | #8 |
Drives: 2012 1SS Camaro Convertible Join Date: Sep 2010
Ok I have had enough of the GM BS! Just fix the damn tops on the line. There has been a problem for 2 fricken years. Just get it right and quit jacking all of the owners around. It that really so much to ask? You spend 40 grand on a car and don't expect problems right off the bat within the first year.
Rant over
2012 1SS Crystal Red Convertible
"Cherry Bomb" Winner of the #NameThatCamaro Spring Special Edition "Green Flash" |
07-30-2012, 06:40 PM | #9 |
Drives: Oracle Camaro has all the bells & Join Date: Jul 2010
I've not had any problems with my car that I purchased 4/11/12. Are the back windows glass or plastic???????
07-30-2012, 07:53 PM | #10 |
All the windows are glass. There was no provision designed in it if the glass breaks. If it does, a new top is required per the installer of the top on my old car. I would accept nothing less as you will only have problems if they try to stitch it back in.
07-30-2012, 09:48 PM | #11 |
I took a pic so you can get a feel for what it's doing. And no it is not condensation. I know the difference. This car has never seen a raindrop btw. Just an occasional wash. The water trail on the inside is akin to leaving your window cracked and a small amount of your water spray entering thru that crack and running down the inside. I can literally take something small like a popsicle stick and slide it between the glass and the trim channel that it pulled out of. Granted it's small for now, but I can only see it pulling further apart untill the whole top of the window drops out of that channel. I assume it could be put back, but what would keep it in place a second time around. If it pulled out once, I would think it would do it again. It doesn't appear to have been glued from the factory--just press-fit into that channel.
07-31-2012, 12:41 AM | #12 |
07-31-2012, 12:47 AM | #13 | |
(2.) evlar says his dealer just "ziplocked it back in" the channel. |
07-31-2012, 10:56 AM | #14 | |
I look forward to your response. Brandon Chevrolet Customer Service
Thread Tools | |
