08-08-2015, 05:40 PM | #1 |
Drives: 14 1Le --14 chevy ss sedan 07shelby Join Date: Sep 2014
750 to 850 rwhp club what combos you got !!
just was wondering what combos are being used to get 750-850 rwhp
08-08-2015, 07:21 PM | #2 |
Sittin side ways
Drives: 2010 2SS/RS IOM Join Date: Nov 2012
I'm the president of this club.
850+hp club member
Procharger F1-A |
08-09-2015, 07:59 AM | #3 |
Well hopeful I will be president of the 1100 club soon as I'm building a nasty 416 ... I'm only running a novi 1500 so I'm thinkin 801 on a loaded Dyno ain't to shabby ... Just glad to be able to skip over the 700s
08-09-2015, 07:58 PM | #4 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
ZL1 / stock blower / HC / E85 and Meth
About a year at 750 and now at 800 Sakudog 13 ZL1 09 CTS-V
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
08-10-2015, 07:03 PM | #5 |
Drives: 2011 2ss blk/wht strp Join Date: Oct 2014
dont get caught up in the numbers unless it a 1/4 mile number.
08-10-2015, 08:12 PM | #6 |
LSX Bumblebee
@Sakudog, what upper pulley, and what lower pully?
LSX 427 | ZL1 Driveline | LSA Blower | Stage 3 BTR PD Cam | 85 lb. Injectors | ZL1 Pump | ADM FPCM | Pulley
LSX Bowtie Block Blueprinted by Gilroy Automotive Machine | Assembled by LSXBumblebee/Arnold Crocker Build Thread: LSX_Bumblebee's 2014 LSX Camaro 2SS/RS Convertible |
08-10-2015, 08:18 PM | #7 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Probably a 9.55/2.50 combo, that's spinning the blower full tilt
08-10-2015, 08:19 PM | #8 |
LSX Bumblebee
Yea, I know. I was wondering. To push that you would have to. @ttshovel, I will show you my build when I am done. 427 LSX with the LSA
08-10-2015, 08:25 PM | #9 |
Looking foward to it! Look for my timeslips, going to the track for the first time since the blower install Wednesday!
08-10-2015, 08:26 PM | #10 |
LSX Bumblebee
Yea, you cheat with that 4L80 though. You'll walk my shit with that automatic.
08-10-2015, 08:34 PM | #11 |
Hey now, i started out 6 speed
08-10-2015, 09:23 PM | #12 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
08-10-2015, 10:30 PM | #13 |
Sittin side ways
Trapped 138 on pump with 4.25 pulley. Race gas and a 4.0 pulley should trap 140+ with a 6 speed.
850+hp club member
Procharger F1-A |
08-10-2015, 10:46 PM | #14 |
Too much is never enough!
Twins for me. Im somewhere between 750 and 800.
