07-07-2014, 07:52 PM | #1 |
Drives: 2013 Black 2SS/RS Join Date: Aug 2012
2013 M6 SS launch
I Have a cammed 2013 M6 camaro ss with a RXT Twin Clutch and 20" mickey thompson drag radials... Last yr when i was just bolt on and stock clutch i tried dumping the clutch at and rpm it would fall on it face after mayb 5 feet or so now that im cammed i thought i could dump it but its still bogs at 4k rpm... are we not able to dump? or what do i have to do to b able to dump it or am i stuck with riding it out?
07-07-2014, 11:22 PM | #2 |
Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
Most M6 guys (or any manual) that dump or rev higher than 3k rpm at the line have more difficulty without a lot of spinning.
Before I had any actual drag experience I noticed a lot of manual cars started off the line slower but once past 30-60 ft were able to fly. My own experience (at least so far) is I get smoother launches out of my M6 (I am N/A with the stock clutch but no cam) when I hit the tree around 2K rpm. |
07-08-2014, 09:54 AM | #3 | |
Drives: C6 Corvette Join Date: Sep 2013
2000 - 2500 launches here. No dumping of the clutch. Ride it out through about 4000 - 4500 before Im completely off of it.
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
07-08-2014, 10:41 AM | #4 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Way to easy to spin with an M6. 2500 is about where I'm launching also. Any more and I spin my way to a 2.xx 60'. Launching around 2500, I've cut 1.72's on the stock pzeros. I've had no luck with NT05R's because I don't have a line lock yet.
07-08-2014, 11:37 AM | #5 |
Drives: 2010 camaro ss Join Date: Jun 2010
Now how do you do 1.72's? I have a 2010 ss m6 with 315's nitto invo and the best I've done is 2.2. Any tricks up ur sleeves u might want to share?
07-08-2014, 11:42 AM | #6 |
First, ditch the Invo's. lol. They are way worse than the pzeros. I hated those things. They are too slick to get good grip.
Keep your RPMs around 2500, start to leave before you mash the gas and keep the clutch coming out smoothly. If you feel spin ease up on the gas and keep slipping the clutch. I also have 3.91's and a Trutrac but was getting 1.9's and the rare 1.88 (once) before the swap. Sent from my iPhone using Tapatalk
07-08-2014, 12:44 PM | #7 |
Really I feel the invos stick better than the pirellis. Good pointers though I'll try it this weekend
07-08-2014, 01:29 PM | #8 |
1.72 on stock tires??? how??? I've only been able to get low 1.8's on DR's
07-08-2014, 01:57 PM | #9 | |
Practice with your Invos but you should eventually buy a good set of DR for the occasional track day. |
07-08-2014, 02:20 PM | #10 |
Its my dd so I'll just have to hold off on other tires. I'm much more interested in how it performs on the street. I'll still take it to the track this weekend any other pointers guys
07-08-2014, 09:09 PM | #11 |
How are all of youll spinning and im bogging?????? what are you doing that im not?
07-09-2014, 07:14 AM | #12 |
Drives: 2010 camaro Join Date: Aug 2009
most are riding out clutch, also hard dumping will put a lot of strain on the slave cylinder..nothing worse then blowing it out and having to get towed home...after blowing out 2 , I went auto....not worth the down time and expense...especially if you are 500 miles from home..imo
07-09-2014, 12:35 PM | #13 | |
I've had my best luck lauching at lower rpms where some like leaving at 4k-4500, my car seems to like lower rpms.
07-09-2014, 05:51 PM | #14 |
Im launching at 2500 as well. My goal without any more mods is 1.7s. That should put me in high 12.2 or low 12.3 I imagine with cooler temps out. Good job on doing that with an M6 om stock tires!
Thread Tools | |
