Old 11-07-2012, 04:17 PM   #1
kostnkost
Roof expert detail noob
kostnkost's Avatar
Drives: 2013 BRM 2LT RS
Correct tire pressure
Just switched out my summer Pirellis to a set of BF Goodrich TA 245/55 R18's. I was curious what the exact tire pressure would be for these tires on my '13 RS? As of now the person whom I bought them off of had them inflated to 32psi from his '11 Camaro. Is this correct?
kostnkost is offline   Reply With Quote
Old 11-09-2012, 05:02 AM   #2
kostnkost
kostnkost's Avatar
Wow looks like I stumped 72 people.
Here is an update to my situation. It seemed the TPS worked right after I installed the tires, but after a 15 minute drive, I received the check tire marker that was blinking, and the read out did not register the tires on the system.
Is there a way to reset this as it was working when I first installed the tires and it read 32psi for each tire?
Old 11-09-2012, 06:07 AM   #3
pwrmanpaul66
pwrmanpaul66's Avatar
Drives: 2016 2/SS 6 spd Dual Mode
32 to 35 sounds about right !
pwrmanpaul66 is offline   Reply With Quote
Old 11-09-2012, 06:16 AM   #4
Blues45th
Drives: 45th anniversary edition v6 3.6L
Yes there is a youtube and I think a thread here on how to rest your tire sensors. Also door jam has proper tire pressure. My2012 says 36 is ideal tire pressure. On cold starts ( I am in florida ) starts at33 and when they heat up run 36 maybe 37 . Hope this helps and look for that video. I just watched it few days ago. Is a setting on your radio panel and you open car door let out few pounds of air till beeps then move to next tire keeps beep and lights flash when it resets that tire
Blues45th is offline   Reply With Quote
Old 11-09-2012, 06:47 AM   #5
twmotox
twmotox's Avatar
Drives: 2013 Camaro 1LT RS
36 psi is correct per the sticker on my door
Loyalty above all else except honor!
twmotox is offline   Reply With Quote
Old 11-09-2012, 09:57 AM   #6
eggydoo
Drives: 2010 Camaro SS
manual states how to reset too
eggydoo is offline   Reply With Quote
Old 11-09-2012, 12:33 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Every car has this sticker on the door or door jam. It's 36PSI for the SS, no matter what tire manufacturer you have. Not sure what the V6 sticker says, but per the quoted poster, it's the same.
+1.
It seems people forget they have a MANUAL for how things work in their car. If you lost your manual, Google has most if not all of it in some form or another. A Google search for 2010 Camaro TPS reset came up with the answer in the very first result.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 11-11-2012, 06:46 PM   #8
kostnkost
kostnkost's Avatar
36 is the correct tire pressure, but remember I switched out my P Zero tires for a smaller BF goodrich tire, so the pressure should be less than 36.
Also for the TPMS system to read my new tires, I need to purchase a relearn tool to read the tires, or bring to a dealer for service. This I read from the manual.
Old 11-11-2012, 06:57 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
For 2012s and up yes you need a relearn tool. But any ol' tire shop has one. No need to risk the dealer damaging your baby just to reset the tire sensors.
Click to view my build thread
