Old 03-09-2011, 08:50 AM   #1
Bama 2SS/RS
Bama 2SS/RS's Avatar
Drives: 2011 Inferno Orange 2SS/RS
Electric motor noise in dash
I searched the thread, but couldn't find out anything about this. While installing my Valentine 1 radar detector in my 2011 2SS/RS a few weeks ago, I noticed a periodic electric motor hum sound in my dash somewhere. It sounded almost like the fuel pump on my motorcycle does to pressurize the fuel line when I first turn it on. Just a quick whirrr-whirrr sound, two quick noises about a second each right after each other. Then, a minute or two later, it did it again, just two quick motor humming noises.
It was fairly quiet, and I only heard it because everything was turned off. The battery was still connected, so the car had electrical power, but the key was turned off and not even in the ignition. The radio was not turned on, and nothing else was running, to my knowledge. I was just curious if anybody knows what this sound may be from. I don't know if it has something to do with the air conditioning system, or what. The car seems to run fine, and I haven't had any issues with anything, so I don't think anything is broken, just wondering what this noise might be.
Any ideas?
Bama 2SS/RS is offline   Reply With Quote
Old 03-09-2011, 03:21 PM   #2
pennor
pennor's Avatar
Drives: 2011 2LT - 73 Corvette 454
No idea but I've heard the same thing from my dash. I too am curius what it is.
pennor is offline   Reply With Quote
Old 03-09-2011, 03:25 PM   #3
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
I noticed that too. I can't wait to see what it is
cab2g is offline   Reply With Quote
Old 03-09-2011, 03:33 PM   #4
D Day Dog
D Day Dog's Avatar
Drives: 2011 1SS Imperial Blue Metallic
Bump this mystery for posts... ANYONE?
D Day Dog is offline   Reply With Quote
Old 03-09-2011, 03:50 PM   #5
Bama 2SS/RS
Yep... very curious... At least now I know that it's not just my car, or some weird sound I'm imagining. Hope someone on here knows what it is, 'cause I've been stumped trying to figure it out.
Old 03-09-2011, 04:15 PM   #6
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
I think its the CD player checking for a disk, the radio will operate without the key in the car. The ambient lighting will also come on if you do turn the radio on without the key. The radio times out after 10 minutes,but If you make any radio adjustment during the 10 minutes the timer resets for another 10.
My SONY DVD burner cycles like this every day at 9:00pm. I thought my house was possesed when I first started hearing that.
MMC is offline   Reply With Quote
Old 03-09-2011, 04:24 PM   #7
THATS NO M00N
it's a space station!
THATS NO M00N's Avatar
Drives: 2011 Camaro 1LT RS
I've heard this as well, but it's usually when I change the vents on the AC unit.
THATS NO M00N is offline   Reply With Quote
Old 03-09-2011, 04:25 PM   #8
9.8m/s/s
9.8m/s/s's Avatar
Drives: 2011 Synergy LS
I've heard it in my car too
9.8m/s/s is offline   Reply With Quote
Old 03-09-2011, 04:31 PM   #9
bmorecam
does it sound like a old cd player spinning?
Old 03-09-2011, 04:37 PM   #10
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
Any chance that it could be the pop-up navigation system trying to get out of the dash?
I am sorry, I was just in one of those moods.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 03-09-2011, 04:44 PM   #11
Bama 2SS/RS
In my case, it doesn't sound like a CD spinning, it sounds more like a pump pressurizing something. My old motorcycle, when you would first turn it on (but before cranking) you'd hear the fuel pump spin up with a soft "whirrr" sound for a second or two, and then stop, as it pumped up the fuel lines to pressurize them.
I'm not saying that what I heard ISN'T the CD player, just that it sounds more like a pump pressurizing something. As far as the radio time-out... I have played around with the radio with the ignition off, so I know it will work without the key, but at the time I noticed this noise, the car had been sitting for several hours before I got in it, and I did not touch the ignition or the radio controls or anything else. Would just opening the door cause the radio to "wake up" like that and check for a CD? Sounds plausible, but I don't know if I completely buy that. I would definitely imagine that if you sat down and pushed the buttons on the radio it would "wake up" and then check for a CD, but without touching anything? I'm just not so sure.
My best guess (and this is just a random, out-of-left-field speculation) is that maybe it's some small pneumatic pump to operate the ventilation sytem dampers. I think most cars I've had in the past, when you switch from say "window defrost" to "floor vents" you'd hear a soft "whoosh" of what I always presumed was some pneumatic system shifting dampers around in the ductwork. Of course, in those other cars it could have just been the sound of the ventilation air whooshing as dampers close. I never gave it much thought. I've never paid attention to what this car sounds like when swapping around the vent paths, I might have to check that out.
Like I said, that's just my best guess, but it could just as easily be some extra-terrestrial transponder contacting the GM mothership, for all I know.
Old 03-09-2011, 04:48 PM   #12
Bama 2SS/RS
One of these days I'm going to have to look into some sort of kit to install said navigation system. I kinda like the look of that Alpine setup that's supposed to be coming out. ...is it threadjacking if it's your own thread you started? Anways... maybe someone on here will know for sure what the weird sound in the dash is.
Old 03-09-2011, 04:51 PM   #13
binlow84
binlow84's Avatar
Drives: '10 Camaro, IBM 2LT/RS
I've heard the sound before as well, and can confirm it is NOT the CD player as the first time I heard it the radio was on and I even popped a CD in to check and it wasn't it. There was some discussion in a thread a while ago that it may be OnStar transmitting/receiving or even something with the car's compass, but we never got the final answer.
[Insert obligatory car/order info below]
2LT RS; Imperial Blue Metallic w/ Silver Rally Stripes; Gray Leather Interior; Automatic; Exterior Painted Interior Trim Panels; Blue LED Footwell Lighting; Dash ABL; DRL Halos
Ordered - 1/16/10 at Weber Chevrolet in Granite City, IL (Excellent experience; Thanks John!)
Produced - 2/24/10
In the driveway - 3/4/10
Total time order to delivery - 47 days
binlow84 is offline   Reply With Quote
Old 03-09-2011, 04:55 PM   #14
SDubATC
SDubATC's Avatar
Drives: 2011 2LT/RS 6M CGM w/black stripes
I don't know much about cars or how they work, so this suggestion is probably wrong, but could it be the anti-theft system working? I know its got that little light where the dash meets the windshield that blinks in the interval that you stated (at least I think I remember it doing that). Not sure if it would make any kind of pump-like sound, but I'm just throwing it out there...
SDubATC is offline   Reply With Quote
QTP Electric Exhaust Cutouts Pictures and Videos!!! Quick Time Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 51 08-08-2015 09:09 PM
GM Extends EV Development with Demo Fleet of Electric Chevrolet Cruzes Mr. Wyndham General Automotive + Other Cars Discussion 3 09-26-2010 03:28 PM
DIY Dash and Door trim for under $30 Darth Martel Camaro DIY & HOW-TO instructions & discussions 29 09-15-2010 06:49 AM
Chrysler's plan to beat the Chevy Volt bigralph General Automotive + Other Cars Discussion 10 12-16-2008 09:16 AM
