Old 02-13-2018, 11:34 AM   #1
W.E.G.
breaker of things
Drives: 2011 SS and 1988 Sport Coupe
2011 SS automatic - drop the pan or just drain?
Dealership says there is no point in dropping the pan, and replacing the "filter" because the filter is just a mesh strainer. No consumable filter element present.
I know kits are available that include the gasket and the "filter." Very inexpensive.
But really, is there any point in dropping the pan to replace the "filter" if the filter is only a screen? If its only a screen, its not like the screen is catching any fine-particulate matter. Without a true filter element, the only way you get rid of fine particulate matter in a transmission is through regular replacement of the fluid.
Yes?
We don't (at least not many of us) drop the oil pan for the sake of replacing the oil pickup screen.
Interested in perspectives of folks who may be better informed than (or in agreement with) the service writer at the dealership.
https://www.gmpartscenter.net/oem-pa...aGV2cm9sZXQ%3D
W.E.G. is offline   Reply With Quote
Old 02-13-2018, 12:12 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
There's really no harm in replacing it, but the way I look at it... If your plates are wearing enough to clog that much filter media, your trans is on the way out, and a filter isn't going to fix it.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 02-13-2018, 02:24 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The automatic is a sealed system. The only way to completely drain and replace the trans fluid is to drop the pan. Since the filter comes with the pan gasket, might as well use it.
Old 02-13-2018, 02:56 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Drop the pan, put in the bigger filter. May be a good time for the Jannette dip stick:
http://www.camaro5.com/forums/showthread.php?t=380751
http://www.camaro5.com/forums/showthread.php?t=480585
-Don
747 RWHP 794 RWTQ
Old 02-13-2018, 03:38 PM   #5
W.E.G.
breaker of things
Regarding the dip stick addition, is there any fluid-level related reason that would dictate installation of a dipstick as part of a transmission fluid change?
