Old 12-09-2014, 03:09 PM   #1
PEW-PROFESSIONAL
PEW-PROFESSIONAL's Avatar
Drives: 2014 Chevy Camaro 2SS
Under car LED's
I'm going to be added LED's under my car for cruse ins and other events. I want to get the opinions of people that have installed them under their car. After talking to the guys at Night Owl I have decided to use their SL Module. What else would you consider I would need besides the wire and normal install stuff. I will be Soldiering these as I have been told the push on connectors really suck.
Here is what I have right now
5 Reels of IP65 Epoxy Waterproof 12V 5M SMD3528/5050 300 Flexible RGB LED Strip Light
Roll o 3M automotive tape
24 Mag Daddys
Here are the locations of where I will mount the led strips (Red boxes)
Any tips are greatly appreciated
PW
PEW-PROFESSIONAL is offline   Reply With Quote
Old 12-09-2014, 04:41 PM   #2
canecorso69
run ur car not ur mouth
canecorso69's Avatar
Drives: 2013 1LE
If the front set of LEDs is on the bottom of the splitter I would be afraid they would be damaged...esp on lowered cars.
TSP headers, cat delete, x-pipe, atak, RPM custom cam and tune, Phfadt 1.25 springs, 15" Carlyle conversion, Nitrous Outlet, Procharger F1A-94, Meth inj
canecorso69 is offline   Reply With Quote
Old 12-09-2014, 05:55 PM   #3
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
I have mine in the same locations, The sides are not as long though. And the one on the back you can move back a little and start it up the sides, this will direct more light out along the back
Don't forget to get the 4 wire cable as well.
having plugs for a quick replacement of strips may be a good option for problems down the road. I believe Joe (NightOwl) can make you up some lengths of cables with plugs on the end that you will have to solder to the strips.
Don't forget to prep the surface well with some wax/tar remover.
Yes soldering is the best way, If your not good at soldering to the thin circuits of LED strips I would suggest you practice, practice, practice. before cutting the strips to length.
2 5meter reels is more than enough to do your under carriage
3M emblem/molding tape sticks the best, be sure to remove the stuff that comes on the LED strips first.
24 Mag Daddys
these things are awesome
PW
here is how mine are on the back.
and the front
GVA 45TH 2SS is offline   Reply With Quote
Old 12-09-2014, 06:10 PM   #4
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
I would suggest dual-wall, heat-shrink tubing, liquid electrical tape, or, just silicone to seal the strip connections. The first two are faster.
You could put a weatherproof SL up front, or, a regular one in the trunk. Either would be good spots to run the wires from.
sjmautoprod is offline   Reply With Quote
Old 12-09-2014, 06:57 PM   #5
PEW-PROFESSIONAL
Thanks for the tips guys. I have tons of experience soldering, I was an avionics tech in the Navy working in F-14 Tomcats. The only other question is if I want to program the light to strobe and do bunch of cool stuff, do I need two controllers?
Old 12-09-2014, 07:07 PM   #6
sjmautoprod
Drives: '16 2SS
One SL supports four, RGB devices. Those could be the four strips, and, you can run them all independently, or, in sync.
Old 12-17-2014, 09:55 AM   #7
masonacdc
masonacdc's Avatar
Drives: 2LS Inferno Orange "PHOENIX"
Have you started yet excited to see results
PHOENIX 323HP "LEGENDS NEVER DIE"
masonacdc is offline   Reply With Quote
Old 12-17-2014, 10:03 AM   #8
ELIC1
Drives: black and silver
i had these at one time. had to get rid of them as the only lasted a year. good luck
ELIC1 is offline   Reply With Quote
Old 12-17-2014, 08:37 PM   #9
Dave@Sturgiscamarorally
Dave@Sturgiscamarorally's Avatar
Drives: 2010 ABM 1SS
Been thinking about doing this for shows. I want to do just white and blue though... have them alternating
2010 Aqua Blue 1SS
KWC 3pc forged, Seibon hood, ZL front end, MGW, ARH full exhaust w/ Doug Thorley axle back, BTR4, Roto-fab, LSXR 102, NW 102, 3.91s
Dave@Sturgiscamarorally is offline   Reply With Quote
Old 12-17-2014, 11:03 PM   #10
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Finally just got done ordering my new lights for the car.
Diode Dynamics set up for the engine bay,
6# strips of RGB SMD 5050
2#strips for the grill
controller
Underbody from LEDGlow
went with solid Green for this.
I'll take the six LEDGlow strips from the engine bay and move them to the interior.
Then move the scanner bar to the trunk
Still have 2 strobe lights to figure out what to do with.
should light up like a xmas tree when I'm done....
BIO-HAZARD is offline   Reply With Quote
Old 12-17-2014, 11:16 PM   #11
PEW-PROFESSIONAL
Not yet, my job has had me extremely busy. Looking to next weekend to get it done. I'll post pics and everything as soon as it's complete!
Old 12-18-2014, 03:27 PM   #12
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Got my LED Glow under body kit to day . Fast shipping . Opened it up and man the tubes are a little bigger than I expected , Not going to be fun mounting these . the side ones will be easy ,but the back one isn't going to be easy at all . Hoping to hook them up and check them out . Wont be installing these till April or May . After winter . Wish me luck ..LOL
Old 12-18-2014, 03:54 PM   #13
ELIC1
good luck
Old 12-18-2014, 09:45 PM   #14
BIO-HAZARD
INFECTED
BIO-HAZARD's Avatar
Hooked the Led Glow under kit up inside to test it out . WOW . This is alittle powerful set . I choose the solid green for the car . And They are supper bright . Very impressed . had fun playing with it all day , My son says it looks sick . I blinded the wife & daughter ..LOL .
The tubes are pretty big , 1 inch round . They will fit really nice under the ACS rocker panels . Have to figure out the front splitter and rear diffuser .
But when its done I think its going to look cool as hell.
