08-25-2009, 10:15 PM | #1 |
Banned
Drives: beated up old mini austin Join Date: Jun 2009
vvt and LIFT
I wanted to start this topic because i feel this is the only technology missing from this hi tech engine....valvetrinic like bmw or variocam like porsche are two unbeatable systems. Continually variable lift so you have the perfect (most aggressive and most mild) cam for every rpm (THIS IS IN ADDITION TO VARIABLE VALVE TIMING OF COURSE)!!!! Tell me what you think!
08-26-2009, 09:02 AM | #2 |
V6 - It just isn't normal
Those and VVT are the same thing with different names. They all accomplish the same thing
2LT RS M6 RJT Black leather 4/29/2009 Ordered 6/24 6000 Delivered |
08-26-2009, 09:15 AM | #3 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2009
x2..and thats also what tends to make tuning a nightmare in accordance with the direct injection
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst- Mods: Corsa catback, SSE, Vararam |
08-26-2009, 09:25 AM | #4 |
San Diego Head Tuners
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8 Join Date: May 2009
Then no wonder BMW did it, they have been so anti-tune
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4) Member of San Diego Head Tuners https://www.youtube.com/c/MojaveKY https://www.instagram.com/mojaveky/ https://twitter.com/MojaveKY http://dinowax.refr.cc/bryanm 15% off DinoWax orders |
08-26-2009, 09:31 AM | #5 | |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
but what I really want from a tune is to reduce the torque management a bit... firm the shifts up a bit... but leave the engine calibration alone.... no messing with timing, fuel, etc... that's what I'm looking for! LOL
08-26-2009, 11:36 AM | #6 | |
Banned
With porsche the way it works(as in the pic) is that if you look at the cam lobe you have an hole in the midle and the more rpm you get a little finger in the middle act as the profile changer to push the valve a couple more mm to get more air in!!! |
08-26-2009, 11:39 AM | #7 |
you want really cool and variable.. check out the VCR (variable compression ratio) engine!
http://www.mce-5.com/introduction/index.htm
08-26-2009, 11:58 AM | #8 | |
Banned
08-26-2009, 01:50 PM | #9 |
It's porches version of vvt... They all work to accomplish the same goal which has to do with cam phasing
08-27-2009, 08:54 AM | #10 |
Drives: CTS/CAMARO Join Date: Jun 2009
Four-cam phasing
The 3.6-liter V-6 VVT DI employs four-cam phasing to change the timing of valve operation as operating conditions such as rpm and engine load vary. The result is linear delivery of torque, with near-peak levels over a broad rpm range, and high specific output (maximum horsepower per liter of displacement) without sacrificing overall engine response and driveability. When combined, direct injection and cam phasing technologies enable an unmatched combination of power, efficiency and low-emissions in gasoline V-6 engines. Cam phasing pays big dividends in reducing exhaust emissions by optimizing exhaust valve overlap and eliminating the need for a separate exhaust gas recirculation (EGR) system. By closing the exhaust valves late at appropriate times, the cam phasers allow the engine to draw the desired amount of exhaust gas back into the combustion chamber, reducing unburned hydrocarbon emissions. The return of exhaust gases also decreases peak temperatures, which contributes to the reduction of oxides of nitrogen (NO x) emissions. In tandem with the dramatic 25-percent reduction in cold-start hydrocarbon emissions brought on by direct injection, the 3.6-liter VVT DI V-6 surpasses all emissions mandates, and does so without complex, weight-increasing emissions control systems such as EGR and air injection reaction (AIR). Source: Text courtesy General Motors
"everyone wants to go to heaven. but nobody wants to die" "you gotta pay to play"
SEMA PICTURES-PARTS & CARS http://www.pbase.com/haveblue/sema_2009 |
Similar Threads | ||||
Cam basics | CamaroSpike23 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 76 | 11-25-2015 11:42 AM |
Camshaft Basics | Milk 1027 | Wiki | 1 | 12-09-2009 12:00 AM |
Competition CAMS nearly ready to release their L99 cams for the VVT AND AFM! | PatrickfromMD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 32 | 07-30-2009 05:46 AM |
I need a car lift. Can anyone help me? | mmollo | 5th Gen Camaro SS LS LT General Discussions | 7 | 07-04-2009 01:47 PM |
No Lift Shifting on Camaros?? | 02bluess | 5th Gen Camaro SS LS LT General Discussions | 15 | 02-27-2009 12:38 PM |
